ORD Box Brace Bragging
Discussion in 'OffRoad Design' started by blazd88, Nov 8, 2005.
  1. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    Just wanted to do a little bragging on ORD's steering box brace.
    Last weekend while wheeling (on my side lol) I was using the wheels quite a bit to push the truck around. Having no hydro assist yet makes the box work ALOT harder. So to make a short story the box was ripped from the frame but not because of the brace. The threads were ripped right through the steering box. Frame, bolts, and everithing else were fine. So thanks for the great product otherwise my frame would be toast.
  2. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Interesting.
    When I put mine together way back, I used longer grade 8 bolts to attach the box and then used ny-lock nuts behind the box in an attempt to keep the box tight. Seems to have worked well for 3 years.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    My major box failure involved ripping the mounts off the box altogther. That sucked.
