ORD crossover users - do you need a longer king pin spring with the arm?
Discussion in 'The Garage' started by BurbinOR, May 4, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Posted this on the ORD forum, no response. The 'pocket' on the trunion cap is overall deeper (by the thickness of the arm, apx 1") on the new ORD arm..........any need to concern myself about a longer spring?
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    What you should have is a round spacer to go in there and then the stock spring on top.
  3. BurbinOR
    5,829
    Oregon
    The ORD arm did not come with a spacer..............should it have?
  4. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Not sure, I got mine from Rockstomper. Every one I have seen though used a round spacer. My Rockstomper arm bolts on top of the cap instead of inbetween.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    My Avalanche arm also had the little disk.
  6. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    you do not need a spacer if it is the ORD arm...i did the conversion back in november and just bolted it on and ran...really easy
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Now that I think about it more, doesn't the ORD arm come with the little dome top welded in about even with the top of the arm? I tried looking on their site but, it doesn't seem to be on the catalog page. Anyway, if you don't have the little top-hat looking thing to bolt up on top of the arm, then you wouldn't need a longer spring or spacer. The pocket formed by the little dome cap and the arm replaces the pocket in the top-hat. Does that make sense?
  8. BurbinOR
    5,829
    Oregon
    Yep, it is, you I believe are absolutely correct Russ. Thanks for the help..........I hadn't looked too closely at it and had it masked off for painting.
  9. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    i put mine on on sat and did it like russ said it went very well
