ORD Disconnects not pivoting well - ideas/experience?
Discussion in 'The Garage' started by rcamacho, Oct 29, 2005.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Pivot? Why do you want it to pivot?
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Are you meaning it doesn't move when you want to line it back up and reattach after wheeling ?
    Try a little lube on the non threaded part of the bolt when you put it in .
  4. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    You mean the sway bar to frame bushings? If you tighten them too much you won't be able to swing the swaybar up after disconnecting it.
    As for where the disconnect kit bolts to the spring plates, those should not be loose at all. Park the truck on level ground, make sure everything is hooked up and torque the large swaybar bolts to around 120 foot pounds. I don't think they are supposed to pivot. If they do pivot front to back then something else is loose, possibly your u-bolts.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The bolts shouldn't be loose at all , but they do need to be able to move themselves . You can move them flexing and then they won't line up after wheeling .
    My bolts are tight as can be , but the part the swaybar attaches to can move for reassembly .
  6. rcamacho
    Jul 1, 2004
    1,324
    WA
    Exactly, the 2" tall pivots that bolt to the frame pads should move rotationally to allow for fore-aft movement with articulation. Mine lock up solid. I probably need to take a little material off one of the bushings and lube assy.
