ORD, do you have U-bolts for D60? +Bushing assy ?'s
Discussion in 'OffRoad Design' started by mofugly13, Jan 23, 2005.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    San Francisco
    I need a set of u-bolts, studs for my Dodge D60, I will also need u-bolts for a Ford D70U. Do you carry these? Also, I built my offset shackles, and used a 1.875 x .188 wall DOM tube welded into the shackle at the end where it fits into your flip bracket. So, on your advice, I will be needing a BA175HD bushing assy., but without the outer sleeve. I was also wondering if you sell lug studs, as I want to swap out the ones on the D60 to match the ones on the D70.
  2. Stephen
    Sep 15, 2000
    Carbondale Colorado
    We can definitely get you the bushing assembly, it's just going to be a shackle bushing set since you don't need the outer sleeve, but still no problem. The ubolts could be a bit more of a problem. I know our kit will do the tube side but the diff side is iffy since dodge used a smaller stud. We do have a couple of stud options or you could just go with a bolt like GM did. For the rear, you'd need to measure the tube and we can check it out from there. I think we'll have to special order a set from somewhere. Not too big a deal but not off the shelf stuff like a 14FF set.
