ORD doubler crawl ratio question
Discussion in 'The Garage' started by unick, Dec 19, 2003.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    What would the crawl ratio be for a truck with an 87 700R4, ORD doubler, and 4.56 gears be?
    lmk
    Nick
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    3.06 * 1.96 * 2 * 4.56= 54.698112 /forums/images/graemlins/thumb.gif
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    3.06 x 3.96 x 4.56 = 55.25
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    add in the torque converter for 110:1
    I'm shooting for 153:1 /forums/images/graemlins/grin.gif
  5. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Zakk, how does the torque converter work in to the formula? Are you just multiplying by two? Is it different for different torque convertors? Thanks.
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    The "stall" in the converter allows you to spin the engine without a direct 1:1 coupling to the tranny...the effect is estimated at about a 2:1 ratio (conservative) to maybe 3:1 (optimistic).....
    Once you hit the stall speed of the converter, the effect is gone. But for most of the slow speed stuff we do, this extra 2:1 reduction is REAL and welcomed! /forums/images/graemlins/thumb.gif
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    so in theory would puting a higher stall converter(not much say 1500) create a more optimal state? Cause you would still have the torque mutliplication?
  8. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    From everything I've read, and seen on this site.....changing the stall speed is more likely to make things worse than better.
    Stall is a pretty tough thing to mess with from a "tuning" perspective. It's a PITA to get to the converter, and most of what I've heard indicates that you really need to understand what you're doing or you may just make your setup more unpleasant....
    I forget what factory "stall" is, but I thought it was up in the 2000+ RPM range anyway???? /forums/images/graemlins/thinking.gif
  9. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Thanks for the info. Makes sense I just never really thought about it that way.
  10. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    Close, but it's x2 not +2, big83 got it right. The farther away from 2:1 get the more wrong you will be. Klune-V "Goliath" & an NP241 (2.7:1 & 2.72:1) 102.48:1 vs 75.63:1 or Klune-V "David" & an Atlas (4:1 & 4.3:1) 240:1 vs 115.81:1.
  11. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    What do each of the number stand for in the formula? First gear ratio, low t-case ratio, a constant and gear ratio?
    Ross
  12. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    Trans 1st x range box x x-fer case low x R&P
    700R4 x NP203 range box x NP205 x his R&P ratio
    3.06:1 x 2:1 x 1.96:1 x 4.56
    In the example #s I used his 700R4 and R&P ratio to get the finial drive ratios listed.
  13. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Somewhere in my Granddad's FSM or literature on his GMC motohome it states that the torque multiplication factor of the stock converter is 2.6:1 and cautions that only X p/n converter be used in the GMC coaches as the typical TH400 converter's factor is ~2.0-2.3:1 depending on application. Unfortunately he's already checked, that converter no longer exists in any inventory anywhere in the states.
  14. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    this is what i am shooting for:
    3.06 x 3:1 (wms) x 1.96 x 5.13 = 92.3 /forums/images/graemlins/eek.gif
  15. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    I like this set up.
    3.06 x 2.72 x 5.13 x 2.7 =115.28 /forums/images/graemlins/thumb.gif
    Of course thats also with a $1700 Klune-V Goliath underdrive also. For those also woundering about the David's 4.1 underdrive. It is highky recommanded them not be used on full size trucks. Klune-V info page. /forums/images/graemlins/thumb.gif
