ORD Doubler: Is a twin stick needed, or can I use the std. shifters?
Discussion in 'The Garage' started by zakk, Mar 11, 2003.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I am not locked in the front (yet) but after buring out yet another tranny, I am looking into the specifics of a doubler set up and it seems everyone is running the ORD shift kit with it also.
    I will have an ARB in the front, and the idea of 2wd lo doesn't really make my heart go pitter-patter, maybe because I don't have it, but I do not see the need for it in my application.
    So anyway, can I use the stock 203 & 205 shifters? I know i will not be a ke3l w/o 3 levers down there but i have thick skin /forums/images/graemlins/grin.gif
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    The main problem with this is that you no longer use the 205 adapter which is where the 205 shifter mounts. Figuring out where to mount the 205 shifter could be tricky! When you get everything up in there you don't have much room left to fab anything. ORD's twin stick is nice, and makes the install MUCH easier!
    Mike
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    ah...i see.
    does the 205 have to modified to fit ORD's shifter kit? I know it does for the traditional twin stick...
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Zakk, you are confusing things. The twin stick that ORD sells is so that you have a shifter for the 203 range box and also the 205 T-case which will allow both shifters to come through the factory hole in your floor board. You could also twin stick the 205 so that you have control over the front and rear axles independently of each other. I think that is where you are getting confused by thinking the twin stick that ORD sells is for that purpose which it is not.
  5. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    No, one of the sticks controls the high/low 203 range box, and the other controls the 205 just like the original 205 shifter. What would be really trick would be setting it up for 3 shifters, with the 205 twin stick setup! That is if you could remember what all the shift patterns were! /forums/images/graemlins/eek.gif
    Mike
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    so it's a bolt on thing? I wonder if Bob the Knob will like his new home /forums/images/graemlins/smirk.gif
  7. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    Yep, it is a complete bolt on ordeal! No booty fab! /forums/images/graemlins/thumb.gif
    Mike
  8. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    bolt on is kewl, but while you have everything apart, why not take out the shift rail, do 30 seconds of grinding, and have 3 shifters. its an easy mod and if you run, or in your case, are planning on runnign cutting brakes, you can lock down a rear wheel, shift into front-low, and swing the beast around practically in it's tracks. might be something to look into if you are runnining tight twisty trails.
    -Scott
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    no cutting brakes in my future. Just having the crawl will be enuff to impress me.
  10. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Eee-Zackly. I did this mod to mine, plus bought the line loc's. Im gonna be spinning circles in my tracks! Woo Hoo.
    Zakk, take the time to modify your NP205, chances are you will be doing it anyway. I'm pretty sure you can still use the single stick on the NP205 with this mod and install the lever between the two rails like it was, to have the "simple operation". Then in the future you can pull the lever out, and install two sticks when you come to your senses! /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    where do you see me coming to this? I don't really see the "sexy-ness" of 2lo.
  12. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Zakk,
    2wd single low is my favorite gear!.... Unlocking the front end so that I can steer, backing trailers, and running the easy parts of the trail are the most common uses.
    I'm sure you'll grow to love it! /forums/images/graemlins/thumb.gif
    Marv
  13. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Zakk,
    Marv
    do you have a detriot in front? I have not come into problems with steering, as I am open in the front. I know Scott (4X4HIGH) has a detriot in his D60, and he said he can't steer for crap, but with an ARB would this still be a concern?
    Interesting...wonder how to mod an ORD kit for a twin stick...
    *ponders*
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    With an open front, you won't need it as much but it would still be likely to help. It's still nice to select front only or rear only in any range based on your needs. And it's not that hard to do.
    BTW, once modified, you can't single stick it because the stops aren't there to make the cross bar see-saw...
  15. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I think I'll run it in the "stock" ORD confirguration and see what happens. In time I can mod'd. We all know our projects are never finished, only abandoned. /forums/images/graemlins/grin.gif
  16. Mudzer
    3,639
    Missouri
    After seeing Watson's ARB cost him the TTC and seeing Steve Fox blow an o-ring in his, I have since boycotted ARB. I know they take the abuse when they are locked in, but here in the Midwest, the Detroit is all the rage. If you are running slick rock all the time, then ARB is the way go to.
    Do the Mod, you'll be glad you did. Plus, you can get "Stick-Itus" like the rest of us. /forums/images/graemlins/thumb.gif
  17. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I have a hard time blaming the ARB for my problems, smoking a fuse because too much stuff was plugged into the circuit is pretty much user error. And with manual air contols available all that BS can go away.
    But back to the root of the post, with just the 2 sticks (one 203 and one 205) you'll have a 2:1 rear low gear and can get 4:1 rear low with some pretty simple mods. The rear only positions are very nice with automatic front lockers but not so much necessary with a selectable front. I rarely use rear only unless I'm maneuvering in such a way I need just the rears spinning. For most use the 2 stick does work out just fine.
    These guys are right, the first time someone in front of you hooks a corner with front wheel drive, you're going to want it, but it can be added later. Our 3 stick shifter should be an add-on for the 2 stick and the shift rails can be modified at any point in time also. So go whichever way you want, you have been educated!
  18. Mudzer
    3,639
    Missouri
    OK, maybe that was a bold statement by me. /forums/images/graemlins/blush.gif
    One other problem I've seen with the ARB, the spotter is constantly yelling ARB! ARB! Do you have to be reminded or do you have a good memory Stephen? /forums/images/graemlins/rotfl.gif
    I heard you are in the process of building the tri-stick now, do you have any Pics or should I wait to see Layne's setup?
  19. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I have my 203 comming down this weekend and this was good for me...I will be slowly building my doubler... /forums/images/graemlins/k5.gif
  20. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    is that one of the t-cases Tony and I will be hauling down there?
