ORD Engine Cross Member
Discussion in 'The Garage' started by onebig76k5, Oct 28, 2006.
  1. onebig76k5
    onebig76k5 Registered Member
    Oct 28, 2006
    35
    Huntsville, al
    I need help solving a problem. I replaced my OEM engine crossmember on my 1976 blazer with the ORD high clearance cross member. I also purchased a set of Day Star poly mounts from ORD. Since I installed the ORD piece the oil pan (Stock) rest (No clearance) on the crossmember. Has anyone else had this problem. How did you fix it? I shimed (.25 inch) the cross member away from the frame with no improvement and changed the motor mounts back to stock, no improvement. I spoke with Steven at ORD concerning this and he never returned my call.
    After I shimmed, it appeared that I had a solution but the oil pan settled by down on the cross member. HELP.
  2. 89Burben
    89Burben Registered Member
    Jan 3, 2005
    98
    CT
    its hard to see your situation without a picture, however shimming the crossmember away from the frame is going to lower the whole business along with your engine. Either wait till monday to call back ORD, or maybe try putting shims (or washers) in-between the engine block mounts and the engine........ if you need the truck for the weekend.
    Maybe theres a fabrication issue, but again its hard to understand what your trying to describe without a pic.
    hope this helps
  3. onebig76k5
    Oct 28, 2006
    35
    Huntsville, al
    Thanks. Let me go take some pics and I will Submit.
  4. dyeager535
    26,979
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    yes shimming the cross member away from the frame is a bad idea, and it isn't accomplishing anything
    if you shim anything(bad idea IMHO) you need to shim the motor mounts up.
  6. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    I have the ORD engine crossmember too... I also have the ORD motor mounts and my oil pan is cleared from the crossmember just over 1/8".... I think the stock motor mounts are too soft, thus allowing engine weight to droop? Try switching to ORD motor mounts, that should put the engine right where it needs to be..
    I love mine and feels more rigid than stock.
  7. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    motor brackets?...
    Are you sure the brackets on the motor are 4x4 ones??...passenger car and 2wd trucks have different ones that have the thru-bolt holes 1" closer from the block than the correct 4x4 ones do!..I see a lot of trucks with car motors swapped in with the car brackets,and this is exactly what happens!...
    If they are the right brackets,then shimming the motor mounts between the mount and crossmember is one option,as already suggested..you'll need at least 1/2" more by the looks of your pictures..I've "fudged" a few trucks I swapped motors in with the car brackets (all I had at the time) by using longer bolts,and stacking a few 1/2" nuts under the motor mounts ..(used them as spacers)...:crazy:
  8. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    only fix for that is to pull the lower crossmember out and cut the tube in half the width of you pan area that hits and weld in a flat plate.
  9. onebig76k5
    Oct 28, 2006
    35
    Huntsville, al
    Thanks very much for your response. The guy that built my motor stopped by to take a look and his response was pretty much the same. He said shimming was a bad idea. The Blazer is a one owner and I know for sure everything was stock (No 2wd or car stuff) before I went tinkering. My plan is to contact ORD again on Monday and see if I can this one replaced. Question would a big block cross member offer any more clearance? If I can't get any assistance from ORD I will have to modify this unit "i.e. weld in a plate etc.
  10. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Ord is really good about this stuf... I would not cut up a product i just bought and modify it to make it work. it should come ready to clear everything...
  11. Teamstatic2001
    Teamstatic2001 Registered Member
    Dec 24, 2005
    92
    Muskegon, MI
    Uh oh on my project I have the crossmember but no engine installed yet, when I ordered mine they didnt have any bigblock crossmemeber. Anyone know what kinda problems ill run into and if a afterarket pan will fix it.
  12. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    j/k... but would make it clear.
  13. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Is that an aftermarket pan? If so...I'm willing to bet that's your problem.
