ORD Greasable 1/2" Bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Junkie, Oct 13, 2000.
  1. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    ORD Greasable 1/2\" Bolts
    UPS just delivered them today. Just waiting on the Hill 4Wheel Drive shackles till they go on. My question is, what type of grease should i grease the greasable shackles with?
    Joe
    http://k5junkie.coloradok5.com/
  2. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    Re: ORD Greasable 1/2\" Bolts
    I would use a waterproof grease like the ones that you would pump into a boat trailer bearing. probably go to a marine shop in your local area and ask them what they recommend for boat trailer axle bearings.
    Dan
    <font color=red>get involved with land issues or lose the land</font color=red>
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    How much were the 1/2" bolts and bushings without the shackles? thanks.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MT/R, 15x10 Bajas
  4. gassman
    gassman 1/2 ton status
    Jul 12, 2000
    131
    Quincy Cailf, Plumas County
    Just got my BDS 4" lift and am very interested in the ORD greasable bolts. Will they work with any lift kit or what mods are needed.
  5. K5Junkie
    Mar 29, 2000
    499
    Gulfport, MS
    gassman -
    Call OffroadDesign, they are very helpful. I believe you have to order new shackles though, to utilize the 1/2" bolts b/c you stock bolts are smaller.
  6. gassman
    Jul 12, 2000
    131
    Thanks for pointing me in the right direction.[​IMG]
  7. mybeast
    mybeast Registered Member
    Oct 10, 2000
    95
    Simi Valley, Ca.
    Does anyone know if these will work with the ORD shackle flip kit, and 4" skyjacker springs?
    When all else fails MASH the skinny pedal!
  8. waxer@work
    waxer@work Registered Member
    Aug 3, 2000
    32
    Ofcourse they will
  9. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Does anyone worry about shearing the hollow (greasable) shackle bolts? I wonder, since I once sheared a solid shackle bolt on the front of my crewcab dually. I am leery of hollow bolts for this reason, and besides, a crewcab dually isn't meant to articulate anyways, right? LOL!!
    ken
  10. K5Junkie
    Mar 29, 2000
    499
    Gulfport, MS
    I have never thought about shearing the bolts off. But i guess i will take my chances b/c i already have them[​IMG]
  11. CK5
    May 19, 1999
    21,623
    701
    CO
    Ken, did this happen before or after you launched the crew cab 30 feet in the air over a sand dune? [​IMG]
    5,000 Pounds of American Rolling Steel
  12. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    AMSoil makes a synthetic grease that will not mix with water, breakdown due to heat or become bubblegum in cold weather. Been using it for 17 years. Works wonders in wheel bearings.
