ORD Greasable Bushings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Derf00, Nov 27, 2001.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    If you don't have them, put them on you Christmas list. While installing our new BDS lift, I noticed that the shackle bolts on our old lift which was about 1 1/2 old were rusted so bad we had to cut them out. I am sure that any rough riding suspension that doesn't have greasable bushing would be greatly improved by adding them.
    Derf00
    1990 K5 Jimmy 350 Edelbrock Performer TBI, 6in BDS Lift, Dana 60 4.56, Corp 14B Detriot, 16x10 Rock Crawler, 37x12.5 SSR
  2. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Derfs RIGHT! [​IMG]
    Those greaseable bushings really softened up my stiff-riding truck... it's easy to forget that bushings in a 30-year old truck can't be expected to still "do the job"...
    I'm really happy with mine!
    My new .sig from now on should be:
    "Making my truck better....one ORD-product at a time" [​IMG]
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Hmm thanks I'll consider that since my truck rides like a tank, do you think it would improve the ride even without new springs
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Fumes,
    You bet....My truck had 4" lift spring in the front, and has a 4" block out back with the stock spring.
    The front bushings were fairly new, but even still....they were rusted and frozen and would NOT pivot like they're supposed to!! The rears are 30 years old, so when the shackle flip gets here (Friday!) I will find out what kind of improvement THAT will be......
    It seems like the greaseable bushings are "transportable" anyway....so use them with your current springs, if you decide to get different springs later, you can just swap them over....You'll want to have them eventually anyway.
    -Greg72
  5. chevyfumes
    Feb 24, 2000
    38,584
    266
    Yeah I hear ya sweet... thanx
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    Stock-type rubber bushings still work after many years, because the rubber twists and nothing has to slide. Poly bushings, on the other hand, have to be greased regularly in order to work at all. I just wish that you could get stock-type rubber bushings for aftermarket springs.
    <font color=green>Oh man, 4:10's are sure better than 3.08's!</font color=green>
  8. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Actually, the rubber is supposed to absorb some of the shock put on the truck by the road. The rubber is not supposed to have to twist. The bolt that gos through the sleave in the bushing is supposed to twist as well. At least that is how i have always understood it.
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  9. Blue85
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    They are made from vulcanized rubber that is bonded both to the inner and outer sleeves. That is why they don't squeak. That is also why you can hardly get them apart.
