ORD Greasable rear bushing install Q
Discussion in 'The Garage' started by Mastiff, Aug 9, 2003.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I'm attempting to install some of the ORD greasable rear bushings. I got the shackle off and all cleaned up, and I have the ORD bushings in the shackle. Now I'm trying to reinstall the shackle in the hangar. Things is, it's REALLY tight. Am I supposed to have to pound them in with a rubber mallet? It would seem to defeat the purpose of the greasability and all if there is so much pressure against the bushing from the hangar.
    I'm not sure if I should just pound it in, or if I should somehow try to spread the hangar opening apart a little (how?). Thanks for any advice! /forums/images/graemlins/ears.gif
  2. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Well, not sure if I did the right thing, but I made a feeble attempt to spread the hangar a little bit so the shackle wouldn't be so tight. I spread it some, but also made it kind of "V" shaped... /forums/images/graemlins/frown.gif Anyway, it's a little less tight now so I could push it in without a mallet (still hard though).
    And what a PITA getting the spring lined up with the shackle. Sheesh. I got the bolt in one side and the other side refused to line up still. I eventually got it close enough that I could screw it through.
    Definitely not as slick an install as I had pictured! Only four more sets of bushings to go. /forums/images/graemlins/tongue.gif
  3. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    patience and beer....
  4. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    I had the same problem when i replaced my new springs. I just spread the hanger open enough to line the bushing hole up and tighten everything.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    At least you got your shackle off. Mine never did come apart. Thank God my friend had some.
  6. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    How'd you spread it? I put a pipe wrench down over it and then got a piece of pipe around the handle, Problem was that it mostly bent the top of it, not as far down as I wanted. I also tried putting a piece of all-thread in there with two nuts both on the inside and using it as kind of a spreader. I think this kind of worked, but a lot of it sprung back when I loosened up the nuts.
  7. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    You mean the bushing? How could you install your friend's shackle without getting yours off?
