ORD Greaseable Bushings
Discussion in 'The Garage' started by IronMan, Jan 10, 2003.
  1. IronMan
    IronMan 1/2 ton status
    Nov 16, 2002
    223
    Bay Area, CA
    I am in the process of installing ORD greaseable bushings in my leaf springs. Which grease can you use? I normally use the red high temp stuff. But someone told me it will ruin the bushings. Any info is appreciated
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I don't see how.... /forums/images/graemlins/confused.gif
  3. motorheadnelson
    motorheadnelson Registered Member
    Aug 12, 2001
    80
    Fort Mohave AZ
    Contact the manufacturer. They can tell you the best product to use.
  4. motorheadnelson
    Aug 12, 2001
    80
    Fort Mohave AZ
    Fumes probably used the red stuff...didn't ya?
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    High temp grease has nothing to do with the spring bushings as they don't get hot or anything.
    The grease I would use if I were you is marine grease. It repels water and keeps the bushings lubed longer and better than regular grease does.
    The key word here is water, not heat. /forums/images/graemlins/wink.gif
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I used the same grease that I use on the steering components. Just regular lube in a tube.
  7. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I use a blue, marine grease available at Auto Zone. It seems to work pretty damn well.
  8. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Well for my stuff I use this /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Eric
  9. IronMan
    Nov 16, 2002
    223
    Bay Area, CA
    Thanks for all the info, i really appreciate it /forums/images/graemlins/thumb.gif
