ORD HD Tie Rod
Discussion in 'OffRoad Design' started by Langosta39, May 22, 2003.
  1. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    If I get a $90 1.5" tie rod from ORD what do I get? How are the ends threaded? Is the DOM tapped? How deep? Both sides RH thread?
    And a dumb question...when i go to crossover this tie rod will still work for me, right?
    andy
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Typically we run 1LH 1RH end, the tube is reamed and tapped for threads. The tierod works no matter what steering system you use, as long as you leave the tie rod on the knuckles. If you want to go to a high steer setup (tie rod over the springs) you need a shorter tie rod.
