ORD High Clearance HD Engine Crossmember with Competition Style Motor Mounts
Discussion in 'OffRoad Design' started by Tonyraca, Jan 30, 2006.
  1. Tonyraca
    Tonyraca Registered Member
    Sep 28, 2000
    87
    San Jose, CA
    I have the engine out of my 79 Blazer and while cleaning things up I found a crack in my factory crossmember. I was considering upgrading to the ORD HD crossmember and using the ORD Motor mounts as well. Are these compatible with each other? Are there any pics of these components assembled together?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The motor mounts don't bolt directly to the crossmember. They bolt to a bracket that attaches to the frame, so yes they will work together.
  3. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    I asked this same question in the post in the vendor forum and Stephens answaer was "yes". :thumb:
