ORD kit arrived today
Discussion in 'The Garage' started by 78Suburban, Jul 29, 2005.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    The ORD steering brace kit arrived today... I hope it won't be too hard to install.. I'll start the install wednesday........ I'll let yall know how it goes..
    Do I need to use blue or red locktite????? do I use it on every single bolt in the kit? what torque should I use, or should I just wrench as hard as I can? Any more tips would be good...............
    If I can't find a 1/2 " bit laying around, would it hurt if I just used a smaller bit and doodled out the pilot how (the instructions say there is already a pilot hole in the frame)...........
    I know I already did a thread kinda like this, but ANY AND ALL tips and tricks for the install are openly welcome... :bow:
  2. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    red locktite on all bolts, bout 80-90lbs would be my guess, sport $ for a 1/2" drill bit if u can.
    not a pro so my best guess :D
  3. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i used a stepped bit (also called uni-bit) to enlarge the hole. it was like 15 bucks at autozone, but i use it all the time now.
    the install is pretty straight forward, just be gentle with the brake hardlines that are in the area.
  4. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    i just got mine today and spent about 1hr putting it in just cuz i had to run to the hardware store to buy some liquid gold.. aka red loctite..7bucks for .20 oz.... insane but i just had some trouble getting it around my brake/power steering lines. Just as long as you unbolt the lil clamps that hold down those lines they will move easily outta the way. Its not hard at all. I just tightened mine down as hard as i could tighten it... ill check it later too.
  5. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    One thing you need to make sure of is that the bolts are not too long. When I got my Steering Bracket brace, the bolts that where supplied with the kit where about 1/2" too long. The bolts bottomed out on the steering boxes threads, and gave me the false impression that they where tight. I fixed this problem by adding three washers to each of the steering box bolts.
