ORD Motor Mounts
Discussion in 'OffRoad Design' started by 83ZZ502_Jimmy, Feb 18, 2002.
  1. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Will your poly motor mounts let me keep my X-member lowered. I have it lowered by about 1-1.5".
    I am getting a ZZ502. I hope they'll work[​IMG]
    Thanks in advance,
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  2. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    ttt
  3. Mobile_Mechanic
    Mobile_Mechanic Registered Member
    Jul 17, 2001
    88
    Phillipsburg, NJ
    I have the poly mounts from ORD. They fit perfectly in place of the original design. Unless you modified an original set, these should bolt right up.
    '84 K30, 6" suspension, 3"body, 350, 350, NP205
    D60, 14 FF W/Detroit, 4.56 Gears, 35" Ground Hawgs
  4. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    To clarify,
    I am talking about the x-member at the T-case. Will these mounts be able to slant the engine enough to get the drop at the back I need?
    Thanks,
    John
  5. Mobile_Mechanic
    Jul 17, 2001
    88
    Phillipsburg, NJ
    I have the engine and trans mounts. They are the same size as the originals but way stronger. So IMO they will work.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yes they will work, I would advise fitting the mounts with the t-case dropped, that way theres no stress on them to start with since they're not going to move around much. Really you can move the rear a decent amount since it starts so flat and it's a long ways between the motor mounts and the t-case mounts. You're talking about changing it about 2 degrees or so, not a huge deal.
    Be aware the mounts may not be a total bolt in, depending on the condition of your frame the bolt holes may not all line up. I had to drill a new hole in my mounts to get them to bolt in. The bolt holes are slotted to keep it as easy as possible but these frames can move a lot. Just so you know.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  7. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Thanks, I'll be ordering soon..
    John
  8. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Will the mounts fit a 1970 GMC w/ 350?
    <a target="_blank" href=http://communities.msn.com/jims70gmc>My 70 GMC</a>
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Nope, we don't have them for the early GM's, only '73 and up. Maybe I'll try to find a set to start on....
    SW-ORD
