ORD Performance Motor Mounts
Discussion in 'The Garage' started by MNNCO, Sep 23, 2004.
  1. MNNCO
    MNNCO Newbie
    Nov 7, 2002
    4
    Question about the ORD Motor Mounts -
    I have a 70K5, I'm swapping in a BB.
    I am using the motor frame mounts and crossmember from a 1985 1/2 ton PU.
    So now I need the actual motor mounts.
    I am not real familiar with the genII motor mounts, but it appears there is a HUGE rubber isolator block and some HUGE mounts on the motor.
    So now my question -
    Can I use the ORD motor mounts and do away with these HUGE chunks of metal and rubber?
    Thanks,
    Mike
  2. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Since your using the crossmember and frame mounts from an 85 they should be a direct bolt up. The ORD mounts are designed to completely replace the OE mounts.
