ORD shackle flip and a 8" skyjacker spring? PLEASE READ NEED HELP
Discussion in 'OffRoad Design' started by gotmud77, May 14, 2004.
  1. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    ORD shackle flip and a 8\" skyjacker spring? PLEASE READ NEED HELP
    I am going to install the shackle flip this weekend and i was wondering if i could just take a couple of leaves out of a 8" spring pack to lower it a bit. I am shooting for a k5 that sites pretty level. Its a little low in the rear. I was thinking if i had a 6" spring and the shackle flip this should be pretty close. I have a 4" skyjacker rear spring also and if its going to be to much trouble i will just put it in there and leave it along.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: ORD shackle flip and a 8\" skyjacker spring? PLEASE READ NEED HELP
    I'd plan on puting the 4" springs in the back. Unless you bought a 2.5" shackle flip. As for removing springs, I'd call Skyjacker and get their take on it.
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    yup. i agree.
    4 inch springs no matter what flip you have. you should sit a bit high then in the rear.
    grant
  4. gotmud77
    Aug 4, 2003
    689
    bellefonte
    it seems that i should probably use the 4" springs in the rear. I think i will do this and see what happens and go from there.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    What front lift are you trying to match?
  6. gotmud77
    Aug 4, 2003
    689
    bellefonte
    I am trying to match a 8" skyjacker soft ride and the rear is a little low. Maybe 1-1.5".
    I just got done installing the shackle flip with a 4" skyjacker soft ride spring and i also installed to front greasable shackles. If i measure the front it is 48" straight above the lock out hub. The rear measurment is 46.5 on one side(driver side) and 47 on the other. Maybe a set of the zero rates?
    As for the shocks i will need longer ones. I am using one the has a extended measurement of 32" and it is all the way out know so i think i need a longer one.
    Thanks again for the great products and i will be testing them out on sunday.
  7. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Where are you measuring? Don't use the wheel openings because the front is cut slightly higher than the rear. Use the body line instead.
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Sounds like you're measuring the wheel openings with those numbers, like he said, go to the body line, it should be level or kick up a bit in the rear depending on the load in the back.
  9. gotmud77
    Aug 4, 2003
    689
    bellefonte
    I am glad to hear that because thats what i was doing. Any way i will have to check it out. Man the shackle flip fixed the driveline angle and vibration. And the front shackles fixed to loose steering. The upper bushings where shot.
    Oh and i got to try it out today and man it works alot better then it did with the 8" springs.
  10. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    What's that little saying...? Oh yeah, making the world better, one truck at a time. Glad we could help you out.
