ORD shackle flip
Discussion in 'The Garage' started by BL1TZKRIEG, Aug 10, 2005.
  1. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    how high does a ORD 4" shackle flip tilt the pinion ?
    will I need a cv or will a normal driveline be fine?
    I'm only doing a shackle flip
    just wondering if it points it at the case ?
    or if it the angle remains close to stock
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Should tip it up about 7 degrees, in a K5 that's usually about right for a CV. A typical block has about a 4 degree tilt to it.
    A k5 with a 4"+ lift will probably need a CV jointed 'shaft.
  3. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    the set up i run is: 4" shackle flip and 1" add-a-leafs on my 14bff with no shims and it works good, i think. i havent gotten it faster than 25mph but so far so good.
  4. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I have ran the flip for years and it always works fine with a stock drive shaft. I first did it with the t case in the up position, then lowered it, both had no problems. Now i have a zero rate back there too and it works great. This is all on a 89 with a slip yoke 241.
  5. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    thanks for the replys
  6. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I installed a 4" ORD flip in my K5 and it sails down the road at 80mph with no problems at all. I'm happy with it.
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I did the shackle flip on my 91 Blazer and the vibration was so bad it made my teeth rattle. I put in a 6 degree shim to point the pinion back down and it got rid of alot of vibration but the yokes made contact in the rear and I still had vibration on take off and about 60 mph. I am going to drop the t case soon to see if it helps. I think I will do the SYE for my 241 eventually and get the kit and a new HD CV shaft from H.A.D. That should take care of the problems. I just don't have $700.00 right now.
  8. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i used DIY4x 4" flip and stock drive shaft. i get a little vibe when i let off the gas at about 100mph
  9. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    at 100 who in the world would do 100 in a lifted k-5 or equivilant with tires over 35? hummm.....
  10. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    uummmm i uh acidently put an uuhhh extra 0 on it :p:
    never drove in cal huh :D
