ORD Shackle Flip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by southerncycle, Oct 15, 2006.
  1. southerncycle
    southerncycle Newbie
    May 25, 2006
    rock hill sc
    I just completed putting on the ORD Shackle Flip kit and it said in the instructions to check the pinion angle with the transfer case and make sure they are within 2 degrees of one another. Where do I go about checking for the correct angles. Any help would be appreciated. Thanks
  2. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I am running the ORD kit and had to put a 6deg shim in there to get the right angle. you want the pinion to point slightly lower than at the Tcase. works well on my truck. Mind you that you might have to play with the angles to get it right and keep from having vibrations. I also have tcase drop spacers from super lift.
  3. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Also depends of if you have a CV rear shaft or not.
