ORD short 32 spline SM465 output
Discussion in 'The Garage' started by atho, Jan 21, 2006.
  1. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    anyone here running the ORD short 32 spline SM465 output?
    I am wondering how far it sticks out of the transmission when installed.
    (this is meant to be used with the stock 465/203 adapter)
    also, what is the spline depth on a long 32 spline female input gear for a 205?
    thanks
  2. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    The long style GM female input gear is 3 7/8" from the face of the case to the end.The splined bore is 2 1/2" deep before it comes up against a shoulder,only the first 2" are splined.
    I dont know the stick out of the ORD 465 shaft but I think that its meant to be used with the 465/203 adapter and the 32spline TH400 203 input.The 203 465 had a short 10spline with a long style female input on the 203 so the ORD 32spline is going to be at least 2" or so longer than the 10spline stick out!
    Hope this helps!
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    thanks a ton!
    i need to go figure out how long the stock 10 spline 465/205 adapter is now. i think i had it written down, but lost it :doah:
