ORD steering box brace?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by midget, Mar 6, 2003.
  1. midget
    midget Registered Member
    Mar 2, 2003
    18
    California
    Has anyone had any failures of the ORD steering box brace? I was thinking of getting one but the local 4x4 shop said they see trucks come in with the brace but still have the cracked frame. Their solution is a frame sleve they cut out of a 1-ton diesel (thicker frame) and "stretch" it around the outside of the existing frame also adding some 1/4" steel on the inner side. They said the frame will still crack just on the outside of where the brace is.
    Anyone with experience in this before I decide which brace to use?
    /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I personnaly didn't use their brace and I have seen SOME failiures with it, but for most cases it cures it and it's a hell of lot better than without it.
    I made a 1/4" thick plate on the inside with spacers in the recess for the bolts. it is bullet proof.
    If those guys offered the plate on the inside go with that it's the best way, because it sandwiches the frame, and for better reinforcement, go with the plate and the brace, that way the frame can not crack around the brace.
