ORD steering brace and weld in kit strength question
Discussion in 'OffRoad Design' started by 79ChevySB, Nov 13, 2002.
  1. 79ChevySB
    79ChevySB 1/2 ton status
    Jul 8, 2001
    178
    Denver CO
    I already have a ORD's steering brace and Im thinking about buying the weld in kit. My question is which would be stronger, the weld in kit with the steering brace. Or having the frame boxed in? If I did go with the weld in kit with the brace, could there ever be a chance of it splitting again?
    Thanks everyone
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i have the weld in and not the bolt in. It is very beefy and i have not had problems with it.
    a combo of the two would seems to me to be nearly invincible. I have the bolt on triangulation part in my garage. just have not had time to bolt it on. /forums/images/graemlins/crazy.gif
  3. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    The weld in kit with the brace holds up very well. If you're into custom fab work, boxing the frame right there, running longer sleeves through both sides with internal gussets and tying it into the front crossmember would work great. But that's really a project for a frame alone, no motor, etc.
  4. 79ChevySB
    Jul 8, 2001
    178
    Denver CO
    Thanks for the info guys. Helps out alot. I think I'll go with the weld in kit from ORD and call it a day.
  5. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    do both...better safe than sorry...i just tore the box off my frame a little over a month ago..bad juju
