ORD Steering Brace: Bolt-on or Weld-on
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Gandolf, Aug 26, 2000.
  1. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    I'm getting an ORD steering brace for my "new-to-me" '89 Blazer. Is the bolt-on as good as the weld-on? Since I don't have a welding set, the bolt-on is appealing, but if the weld-on is far superior, I'll find someone to do the welding. Also, how much does it take to complete the installation in terms of hours and beers?
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I got the "bolt-on" brace. I'm very happy with it. the hardest part was enlargening the hole were it bolts in the front crossmember. After it was installed, a friend just welded the crack on the frame for a beer. I didn't have any more money to buy the weld-on brace. It's been about a month only since I installed it, and still have no problems. Total time of work and beers was 3 hours. Also, check out this board because there was someone selling ORD parts cheaper than ORD.
    Good luck.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Actually I'd say the bolt in brace is the better one. All the weld on brace does is add thickness to that side of the frame. The bolt in piece works as a gusset and triangulates the frame in the area. Much stronger in my book.
    '73 K5
    Chevy good...Ford bad
  4. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    I agree. The ORD brace is a better design, and stronger. Whats the deal about someone on this board selling ORD stuff cheaper than ORD?
    John
    So Much to do, So LITTLE cash.
  5. jim82
    jim82 Registered Member
    Jun 27, 2000
    71
    Bay Area
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    The weld in brace is primarily to strengthen/repair cracks by the steering box. The ORD brace will triangulate the frame to stop the cracks from occurring. Seems if you are hardcore, doing both is a good idea. Otherwise do the bolt in and the belief is it will eliminate the cracking from ever happening.
    <font color=black>'79 K5 - 406 w/IROC TPI -<font color=orange> K5#5 - <font color=blue>http:// www.blazzinor.coloradok5.com
  7. Gandolf
    Aug 8, 2000
    764
    SF Bay Area
    Thanks for the help. Based on your responses, I've decided to order both braces. My steering box was loose but I tightened the bolts and it didn't flex after that, so I don't think I have any cracks. But when I get it apart to install the bolt-on, I will do a dye penetrant test on the frame. If I discover a crack, I will then be prepared to implement a repair on the spot, instead of having downtime while waiting for the weld-on to arrive in the mail. I may decide to do the weld-on anyway, even if I don't find cracks...I'm thinking about it.
    This website is great. I would have never thought to check my steering box had I not read about it on a post in this bulletin board.
    '89 K5 Silverado 4" lift w/BFG 33's
  8. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I think the best way to go is to get both the brace and the weld on repair kit. I have both on my K-5 and I'm fairly sure that I'll never have to worry about cracks again.
  9. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Gandolf,
    You can check out my site for a write up on the installation of the bolt on brace. In my opinion, unless the frame is already cracked, you don't need the weld on piece. All that really does is after you weld the frame back together, you weld that piece on to reinforce it. Then add the bolt on. But its up to you.
    http://www.boss.coloradok5.com
    At the home page, click on "Mods" section and you'll see a pic of it. Click on the pic and there's the write up. Good luck.
    Boss
