ORD steering brace (INSTALLED) question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Nov 8, 2000.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I put in the ORD brace for my 76 today.
    My frame must be a little tweeked because the hole in the front crossmemeber did not line up. It took about 45 minutes to get it to line up.
    The trick was to use the best tool I have - the BFH. Big friggin hammer.
    The question is, is it going to loosen up since I did not se threadlocker? Because of the problem I had getting it to line up, I did not want to take the bolts out and have to re-line it up, which would have taken another 45 minutes.
    The nuts are nylon self-locking abnd I put some beef on them and the steering box bolts. Did anyone else not use loc-tite and have any problems?
    Looking at how it's designed, it justlooks like it belongs there - looks weak without it. No wonder the frame flexes in those areas.
    -- Mike
  2. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Can't answer this myself, but you may want to contact Steve at ORD to ask him. Also he could probably use the feedback to help others.
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    The front crossmember hole on both of my trucks did not line up, I had to enlarge the hole like the instructions said might be necessary. Locktite is not needed for that particular bolt, due to the Nylock nut. BUT, the bolts to the steering box require locktite. If you didn't put it on them, go back and do it. Better to do it right and not worry about it.
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  4. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Thanks for the advice.
    I'll probably run it for 50 or so miles to break it in, then remove the three steering box bolts ONE at a time, loc-tite it, then go to the next one - the brace shouldn't move if I do it one at a time.
    The nylon-nut one is the one I am worried about moving so I'll just do the 3 box bolts. Thanks,
    -- Mike
  5. tkjimmy
    tkjimmy Registered Member
    Sep 21, 2000
    41
    Washington State
  6. TX Mudder
    Jul 10, 2000
    2,514
    Houston
  7. tkjimmy
    Sep 21, 2000
    41
    Washington State
