ORD steering brace/ oil lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Aug 20, 2000.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I'm finally going to order a bolt in steering brace tomorrow. I'm wondering what I should do about the oil cooler lines, they run right through a hole in the crossmember. Are they in the way? What should I do about it. Thanks.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MT/R, 15x10 Bajas
  2. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    It's a tight fit but the brace bolts up right beside the oil lines
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    So I can just push them under? What about the hard lines? Theres also a couple of greasy lines above...are these in the way?
    Brian
  4. Topher
    Topher Registered Member
    May 12, 2000
    81
    North Texas (DFW)
    If all you have are the stock lines on your truck then you should be able to "nudge" them out of the way. It will be a very tight fit in some cases. And some of the hard lines can be really hard to move or bend but there should be enough play to be able to be able to do so. As common sense dictates just be sure not to damage or kink any of the lines in the process...even when you have the brace in nice & tight double check to make sure none of the lines are getting pinched by it.
    Good luck!
    Chris
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I ordered the brace today, I don't know who I talked to, but they sure were a lot better than the people at 4 wheel parts!
    Brian
