ord steering brace
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KENNY, Sep 22, 2001.
  1. KENNY
    KENNY 1/2 ton status
    Dec 7, 2000
    292
    nyc
    I purchased an ord steering brace from a member of t;his site. I have an 84 blazer. when i recieved the piece it was packaged poorly but that is not the problem. Is there a difference between an earlier years part gu390011-E or L. seems like it wont fit over or under the steering hoses and the brake lines alson the brake valve.
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    You have to remove a few line-hold-down bolts, and move the lines out of your way. You may also have to drill the hole in the cross member to make it fit.
    I had to do all of the steps above, and i bought mine right from ORD.
    <font color=red>Just give me a tank, and point me in the right direction!</font color=red>
    <font color=blue>DONT MESS WITH AMERICA!</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
  3. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    same deal here...it was not just a easy bolt in job...it took a few hours to get it in there...hoses moved holes drilled etc etc
    [​IMG]<font color=blue>Donations accepted for the "Build Chaz's 1972 K5 fund"!!!</font color=blue> [​IMG]
  4. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    one hole has to ben enlarged and sometimes you have to move some lines over a little bit..
    just backing up what was already said.. I have the instructions from that kit that I could probably take a picture of if needed.. email me if needed
    mike
  5. Grim-Reaper
    7,385
    Atlanta
    The newer the truck the worse it gets. If you got the oil cooler it gets fun. On my 75 it took all of 40 miutes to install it.
    Wait till it's in.....BIG improvments that you will notice by the time you make the first turn.
    I don't need no damn shop manual, I got a pornographic memory.
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  6. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    What more is involved if you have an oil cooler? My truck has the factory cooler and I am planning on getting the brace.
    Keep it simple
  7. KENNY
    Dec 7, 2000
    292
    nyc
    thanks for the replies. i thought this would be a simple 30 minute add on wasn't prepared for all the work and mods another question is the photo on the example given on this site has a brace that goes in the front crossmember with two holes. the one ii have has one and its bigger 1/2 iin than the hole. i wish the;y didnt say bolt in if it really isn't.
  8. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    It is a bolt in by all definaitions. The ONLY MOD you have to do is enlarge one hole. I installed it on my 90 and it was nothing. Took maybe and 1 1/2. With pee breaks and coffee or was that beer? hhhmmm.
    But anyway, you have to take some screws out that attach the brake lines to the frame, but those hard lines aren't gonna go anywhere. So just leave the bracket off. Then all you have left is to bend some off those lines outta the way just a tad bit so they dont rub.
    Hell, leaf springs are bolt in but they were more involved than this.
    Good luck!
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  9. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    Has any body ever welded the "bolt on brace" instead of actually bolting it???I have to get one real quick, my frame is ok now but I'm sure it is hurting and would rather not have it cracked!!
  10. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    The way the bolt on brace is designed and layed out, it would not work welded on.
  11. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    On my 89, it went on like it had eyes.....enlarged the brake line clamp hole to 1/2", slightly started the bolts I removed from the steering box, inserted the bolt thru the crossmember, and tightened em up......took that little brace off the front, attached the brace in the kit, and popped a beer.....took longer to pick out the tools and put 'em up afterwards than it did to actually do the job.....delivery was prompt, I was treated courteously, and I feel I got a quality part well worth the money.....JD
    Stuck?...Hell no..I still got some gas left..
  12. KENNY
    Dec 7, 2000
    292
    nyc
    it is the steering pump hose lines that intefere the most. i would bend them but am afraid that they will break (the metal part coming out of the steering pump). the other question is there any difference in parts for earlier and later models. why do some have one hole and others two on the front cross member piece.. the two seem more secure to me.
  13. K5Jimmy
    Sep 21, 2000
    1,141
    On my 89.....on the long brace, I have two bolts to the steering box, and one to the middle of the crossmember.....I simply enlarged that hole...the lines on the crossmember were a non-issue, as they were exactly out of the way....on the small front brace, I got two bolts to the crossmember and one to the steering box......I think that on earlier models, there is one to the crossmember and one to the box, but the long brace is essentially the same on both......I've only seen one on an earlier Blazer once, so the diddference in the front brace is the only thing that stood out as being different......I hope this helps....JD
  14. LAZYMON
    LAZYMON 1/2 ton status Premium Member
    Jul 26, 2000
    235
    Lake Tahoe
    Don't forget to check and retorque the bolts after some driving. My steering was feeling loose again and I discovered I'd lost a couple of bolts. DOH!
    Let The Sun Shine Down Upon My Face
    Topless 73
    <a target="_blank" href=http://coloradok5.com/gallery/On-The-Rocks>http://coloradok5.com/gallery/On-The-Rocks</a>
  15. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Ain't that the truth! I was gonna do it when I did my brake lines and found out that the oil cooler lines are gonna have to be rerouted. [​IMG]
    Ah well, it'll be worth it when it's in.
    If you see my truck on a trailer, call 911 cause it's <font color=red>STOLEN!!!</font color=red>
    Website link is in my profile [​IMG]
  16. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    My oil cooler lines go right up under the brace. I simply took a piece of water hose and wraped it around the cooler lines and zip tied it on to keep from chaffing.
  17. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Just agreeing with what everyone said. I have one and it was a pretty simple bolt in. That one hole in the x-member does have to be enlarged.
    With the small bracket in front of the x-member, I used a die grinder to enlarge the holes and put it back on with the brace.
    I wrote an article on how I did this and it's posted on <a target="_blank" href=http://www.off-road.ws>Off Road.ws</a>, but the site seems to be down right now.
    It's a great add-on for the truck though. It definitely heps with street cornering, and also with keeping your steering wheel straight; even after a hard days wheeling.
    Thomas.
    -- '84 K5 Blazer --
    <a target="_blank" href=http://stoopalini.off-road.ws/blazer>My Blazer Site</a>
  18. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I had to loosen the power steering lines on the box in order to get the brace in. I did not have oil cooler lines, but it was a 30 minute job start to finish and 10 minutes of that was finding the right size drill bit to enlarge the existing hole in the crossmember. Once it was in, I put the power steering lines back to their original positions tighted everything down and retightened the brace bolts after the first week of use. I was able to tighten them a little so I checked them again a week later, but they were tight after that.
    As for being bolt in, technically it isn't because of the hole that has to be enlarged in the crossmember, but it is as close as you are going to get (again this is for a vehicle not equipped with an engine oil cooler).
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
