ORD swaybar disconnect...SOLD
Discussion in 'Suspension | Axle' started by 88K5Jimmy, Jul 26, 2006.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Good shape, you will probably want to get new swaybar bushings where you attach the pin, one was rusty and the pin is tough to get back in. Or you can ream out the metal bushing a little bit and it would probably work fine. I drilled and tapped a grease zerk in the front swaybar bushings. I also made two drop bracket/spacers to go between the frame and front swaybar mounts, because I had a 6" lift. They probably aren't necessary for a 4" lift but they didn't take that long to make so I just whipped them up right quick. Forgot to take a pic but it comes with the swaybar holder when disconnected, which attaches to the passenger side bump stop.
    How about $50, includes shipping.
  2. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
  3. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Offers?
  4. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    Are they hard to re-connect?
  5. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Honestly, I would have to get under the truck (or from in the wheel well) enough to push the swaybar back down and then use a screwdriver or something to stick through the disconnect and into the sway bar to pry it back down to get it to line up.
    I want to get rid of them because the K5 isn't my daily anymore.
  6. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    pm sent
  7. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    pm replied
  8. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Sale pending
  9. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i may be interested
  10. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    guess I'm third in line.
  11. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Sorry guys, it's sold
