ORD swaybar disconnect
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JJ85K5, Apr 29, 2002.
  1. JJ85K5
    JJ85K5 Registered Member
    Jan 2, 2002
    21
    So Cal
    Can I put an ORD swaybar disconnect kit on my K5 with the stock suspension? I'm in the process of replacing all the bushings and I thought it would be a good idea just to put in the swaybar disconnect kit in while I have it all apart. Also, Can I put the greasable bushings in the stock springs and take them out when I get new springs?
    Thanks for all of your help so far.
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    1st question=YES
    2nd question=YES if the stock spring eye,and the aftermarket spring eye are the same size.
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I am going to have to disagree, I had the ORD disco's on my truck for a while before I put my lift on. It seemed like every bump that I hit made the disco hit the holdup bracket and that eventually ripped the bumpstop off. It also somehow (?) managed to make the swaybar itself hit the frame. In the instructions it recommends not using these on lifts of 4'' or less unless using extended bumpstops.
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Heh. funny, I just placed an order with ORD today. bought the Steering box brace and the disco kit. I asked the same exact question, and the answer I got was that it works with stock suspension as well. But then again, I didnt speak to steve, so Im on hold now, just to double check. /forums/images/icons/smile.gif
  5. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    I have them on my K5. It only has a 2.5" lift. Have had no problems at all. Looks as if you would have no problems with no lift. I personally think they work great.
