ORD tomorrow
Discussion in 'The Garage' started by 78Suburban, Jul 24, 2005.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I will order my ORD steering brace tomorrow. (I probably should get the weld on one for extra strenght too, but I am going to try and make do with just the bolt on one for now)
    Anyway, I found an article where peterson's installed a similar product by Autofab, and I noticed that they said a regular drill wouldn't have room to work . They said you had to use some kinda angle head drill. Is this true? I don't own anything but a regular ol' drill :crazy: .
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I don't know about this either as I still have yet to put on one my burb, but even if you do, you can rent a 90* angle drill from a local rental shop for a couple hours for fairly cheap.
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    ehh... IIRC that would be correct IF your engine is in.... call me silly but my engine isnt in... and hasnt been for a long time.... :mad:
    Grant
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    True, if your engine is in. I've installed these twice, and both times I had the engine out, was very easy. I have an angle headed drill but its weak.
    Also, Autofab makes the steering braces, ORD just sells them.
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    well mine is in, so I suppose I will be renting an angle drill :mad: . are there a bunch of lines that run with the chassis that I will have to worry about drilling through?
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    there is one line you have to worry about, I can't remember, but I don't think you really have to worry about drilling through it, just have to bend it out of the way slightly, otherwise the bracket will sit on it.
  7. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I installed it with just a regular drill. The engine was in.
  8. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    was it a small drill or something? was it very cramped to difficult?
  9. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    It was a normal 3/8" drill. It was several years ago...as I recall it was a little tight, but not bad. It didn't take long.
  10. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i did the same...3/8" drill and i used a stepped bit to enlarge it to 1/2" i believe.
    wasn't really a big deal the brace took me maybe half an hour from start to finish. i had the most trouble bolting the other end of the brace to the steering box, was just an awkward position.
  11. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
  12. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I installed mine with my 18Vdc XRP 1/2" Chuck Dewalt drill. It fit in there just fine with a TN 1/2" bit. Took about 30 Minuts start to finish.
    My engine and bumper were installed but the D60 was not.
  13. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    I was able to use a regular drill to drill out the hole in the radiador support cross member (just above the proportioning valve), in order to install my steering box brace as well.
  14. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    same as me but i used a cheap arse ryobi drill 18V cordless
    my whole truck was put together, no problems
  15. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I did mine with a normal 1/2" drill but no bumper and 3" BL at the time.
  16. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The reason AutoFab's brace looks similar to ORD's is because they are both made by Autofab.
    Harley
  17. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i went through the front of the frame on my truck, used my 1/2 air drill, it was also done on a lift at work, alot easier then on your back
  18. 74 chev
    74 chev 1/2 ton status
    Sep 30, 2004
    159
    Concord,CA
    i just used my 18v miluaukee cordless with the motor in it was a little tight but worked great.
  19. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    yep, i had no prob when i did mine...regular dewalt corded drill, correct size bit, bumper and motor in place and went to town on it. It wasn't all that bad to do either. Should take less than an hr...
    Since we are on this subject, were any of yall not able to install the smaller brace on a last run (91, maybe 88-90 also, possibly even a tad before) because GM already had a little brace in there in almost the same position?
  20. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah i had that problem on my stepdad's 91. i just left the stocker there. i dunno if he ever messed with it to ad to the bracing.
