ORD Zero rates... Who here runs them
Discussion in 'The Garage' started by santana, Nov 22, 2004.
  1. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    I'm thinking of running a set of these babies on my K5, right now it sits just a little higher in the rear, (even higher with the top off).. How much will it actually lift the front end and is it a good idea.. /forums/images/graemlins/ears.gif
  2. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Ive got them on my truck, There an easy stable way to add an inch /forums/images/graemlins/grin.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I run them in the front of my K5. No problems yet and they have been in for about 6 months and 3-4 trails. They are a 1" lift.
    Harley
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Zero rates are nice because they bolt directly to the spring pack without stiffening the springs. Because they bolt directly to the spring pack you can use them in the front. I have had mine on for over a year now with no problems whatsoever. I DD my truck on 37's, and wheel it hard quite often. I recommend them. /forums/images/graemlins/thumb.gif
    -Harrison
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    have em front and rear. they wont be up front much longer... but only cause of steering clearance issues and the 52" spring swap... not because of any probs with them. Good product.
    j
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I made my own 1 1/2" ones as I took out an 'add-a-leaf' out of the rear to soften the ride and lost a bit of height. They're a great idea as they are bolted into the spring pack. Made mine straight up but Stephen's can be used to offset your axle too. /forums/images/graemlins/thumb.gif
  7. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I running front and rear with both axles offset 1.5 inches giving me an extra 3 inches wheelbase. No issues at all and they are a solid 1 inch lift. Alot of people keep asking me why I have a block in the front and I have to sit them down and explain the concept. /forums/images/graemlins/screwy.gif
  8. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Made my own on the rear and milled the angle I needed into them.
  9. 84mudmachine
    84mudmachine 1/2 ton status
    Dec 23, 2003
    184
    Kansas
    I would like to put them on if they had 2" ones.
  10. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    Thanks for the replies, I'm sold on them, gonna order a pair ASAP /forums/images/graemlins/peace.gif
  11. davisz71
    davisz71 Newbie
    Sep 2, 2004
    4
    I have a few questions about running these 1. If I off set the front to 1.5" forward will i have any steering issues. 2. With both axles out 1.5" will my drive shafts still be long enough.
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    if you're running stock steering components, almost certainly. If you're not, we need more info on what you have to answer that question.
    probably not... but again, more info is needed. amount of lift? is the drivetrain in the stock location other than the axles?
    j
