ORD Zero Rates
Discussion in 'The Garage' started by 79Stomper, Apr 21, 2004.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Got the lift in last night and was starting to put together before I get everything apart. /forums/images/graemlins/thumb.gif I get the old bolt off of spring pack, no problems, insert new one from ORD and it is way too short. /forums/images/graemlins/confused.gif I got one to thread and commenced to tighten the spring pack and it snapped. Anyone else run in to this who are running zero rates? I am still hot. Called ORD and they said I would have to find someplace else to source the bolts. Now off to the parts store to look for some freaking bolts. /forums/images/graemlins/angryfire.gif Starting to consider if they are even worth the trouble now.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How thick are your spring packs? The bolts that came with mine were super long compared to what I needed.
  3. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Brand new 6 inch lift, noting special about them. Plus they asked how much lift I had. /forums/images/graemlins/confused.gif
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    My spring bolt broke when I was taking mine apart so I just went to the hardware store and bought some high grade bolts then rounded the heads round with a grader and wallla you got a new spring bolt. /forums/images/graemlins/thumb.gif
  5. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Grade 8 allen head bolts work great for spring center pins.
  6. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Napa carries them in stock, they have lot of different lengths too, about $3 each /forums/images/graemlins/thumb.gif
  7. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    Unfortunately, to make the zero rates work right, we have to send a certain length center pin because we can't have a shank on it and still be able to use the offset feature. So a 4" pin is about all we can get. For some that's not enough but without sending a hardware store in the box, all we can do is give our best guess on what most guys will need. They may seem like a somewhat exotic fastener but any grade 2 or better bolt will work, center pins are not hard at all. I've used all the methods mentioned above at one time or another and all have worked fine. Sorry for the inconvenience.
  8. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I have a pair of hand me down zero rates a friend gave me and I just hit the local spring shop for pins /forums/images/graemlins/dunno.gif
  9. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Going to find me some this afternoon and see what I can find. If not, you will see them on the board.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    1. That is absolutely untrue, spring centering bolts are hardened.
    2. No grade 2 bolt has any place in an automotive application. I don't care if it's a valve cover bolt, it should be grade 5 or better. Grade 2 is ok for bolting wood together, and that's about it.
  11. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I call dibs!! I'm gonna order some in the next week or so, so let me know. BTW, I'll take em without the pins as I have 8" ones from NAPA that I always keep on hand. Long spares can always be shortened to the proper length. Besides, easier to assemble when they are long.
  12. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i put my on and had no problems, i moved the front foward and left the rear in place, i always go to lowes and get grade 8 bolts and round the heads a bit on my grinder. If we caint figure it out this weekend we should all give up our trucks /forums/images/graemlins/ears.gif
  13. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    Just what is the "hardness" spec for a leaf spring centerpin?
  14. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif Tim /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif Again /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
  15. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Yes, he was doing OK for awhile. Now back to the same old "I am the all-knowing" Tim. /forums/images/graemlins/rolleyes.gif
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    All the ones I've ever sold were 120,000 psi (grade 8). Might not be specified, but they are made that way. I can't see where high strength wouldn't be required for the pin that locates the axle though.
    As I stated before grade two has no place in an automotive application. Every fastener, reguardless of what it is doing, should be grade five or higher in my opinion. The OEs seem to agree with me too--they use high grade bolts everywhere, even high grade metric bolts in some instances (which makes them a bitch to replace if you have to find them).
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah, roll your eyes. I certainly would like to think this is a pretty important part of the vehicle considering its role in axle location.
    Anyone who'd roll their eyes at a comment like that, I certainly hope you're never on the road or the trail anywhere near me. People have died for much smaller failures than a spring centering bolt.
    To roll your eyes at something like that is the wrong answer, big time. I might not be, "all knowing" but I certainly saw and called out a comment that I felt was unsafe and unacceptable real quickly. Only reason you're rolling your eyes is that either you don't care to know the facts, or you think that its impossible that Dr. Watson could be wrong. Either way, the reason we have a forum isn't to sit here and agree on every issue. Some disagreeing would have to happen or we'd all have the same truck.
  18. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    So your trying to tell me that all the trim on a vehicle is held on by a grade 5 or better sheetmetal screw? /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif Think again
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The bolts that hold your fenders on are probably grade five.
    I've never seen a grade 5 sheetmetal screw but I guess you can't have everything. /forums/images/graemlins/rotfl.gif
    All the trim on my truck is held on by double stick tape.
  20. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    Have you ever actually seen a spring center pin break or broken one yourself? Not very hard.
    He does happen to do this sort of thing for a living. What do you do? Oh yeah, thats right, you work at an auto parts store. And what, for maybe 2 years?
    My rolling eyes is mostly directed to your delivery. You did improve for a short time after posting that sobbing apology in the Lounge.
