Ordered a WMS 3.1 to 1 gear set !!!!
Discussion in 'The Garage' started by tarussell, Dec 21, 2004.
  1. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Sorry for the lame post but I had to tell someone that would understand ( my girl friend just does not see the beauty of such parts ) my excitment .
    I just got off the phone with Casey at WMS and started the build of my Doubler range box low gear set . It should take about 30 day's to get it to my door and I will post up pic's at that time . I know that Ya'll have seen the WMS gears before but I figure if Ya'll are like me you just can't get enough of cool functional parts .
    I guess I should get back to building the rest of my Blazer so that I can actually use all this gear !!!!
    Tom
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I would say congrats, but the green eye'd monster is chewing on my back side, so I'll just say, "I HATE YOU!"
    :haha:
    Seriously, wish I had the resources for that. Enjoy!
  3. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    awesome man :mad: i really want to order it also, but i need to sell my AA gift cirtif first. way to go
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i agree w/ baddog u suck.
    unless u would swap me for my normal 203 range box???:grin:
  5. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    Sweet!! I knew you couldn't live without it. :D
    6.55 x 3.198 x 1.96 x 5.86 = ~240:1 :yikes: :yikes:
    Congrats!! :thumb:
  6. dan dibble
    dan dibble Registered Member
    Apr 30, 2004
    30
    collierville TN.
    Cool with that much gear you will be able to run that four popper you have been wanting to drop in.
    -snickker-
    Do you think you will need that much gear?
    Dan
    BTW: I just pulled my 3.8 and put in a 3.0. I hope to drive it on Thursday (in the snow)
  7. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    it would be too sweet if we actually got some lovely white snow, been a year or 2 since i saw some.:xmas:
  8. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    You can make the electric motor in your washing machine pull a freight train if you gear it low enough. :rotfl:
    Actually, talking with you about going with the 3:1 Atlas helped me to make up my mind to go the WMS route. I figure the 3 low range options (2, 3, 6 to 1) would let me pick and chose yet not limit me to one extreme low ratio. Hopefully, I'll never need to use super dooper ultra low but it will be nice to have that option.
    Besides, I've got to do something to be able to keep up with that bada$$ buggy from Memphis - or at least be able to get to where I can watch it. :D
    The Weather Channel says we might get some Christmas snow down here on the coast so load that thing up and bring it to the swamp!
    Merry Christmas!
    Tom
  9. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Nah, thats so you can just idle over the rocks. :thumb:
    Congrats dood! Maybe someday.... :thinking:
  10. dan dibble
    Apr 30, 2004
    30
    collierville TN.
    What are the motor specs on this beast???
    Dan
  11. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    So these are for the 203 right? Im too lazy to search around wagoners website, what does just the 3.0 gearset cost?
  12. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Yes and a grand.
  13. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    I'll try to answer this since Tom is having computer problems -
    balanced 292
    9:1 compression
    approx 500 lift cam
    Alum intake (Offy or Clifford - can't remember)
    Howell TBI
    He'll be using a 4spd, ORD Doubler 203(3:1)/205, D60, D70 w/ 5.86's and 36" TSL's.
    :yikes: He says he still wants the LOMAX when it comes out. :yikes:
  14. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Dan - I wanted to keep the motor strong in the bottom RPM range so I picked a marine cam grind that creates a lot of cylinder pressure . The compression ratio comes ot to 9.7 to 1 ( I had the block decked and the head as well in combination with LPG pistons ).
    The intake is an Offy , the Clifford stuff was for more race oriented application while the Offy was all bottom end.
    I had the marine thick-n-heavy BBC flywheel balanced and drilled for the 292 . This is the heaviest flywheel that I know of for GM engines - my line of thought is keep the rotating assy. swinging with a butt load of inertia to keep it from stalling.
    Standard machine work - balanced rotating assy. - resized rods w/ARP rod bolts - line bored - New springs/retainers and seat work on the head - and all the usual quality practices.
    I am using a straight cut gear instead of the helical cut timing gears and a HV oil pump with a large capacity pan.
    I figured bone stock old in-line sixes will last forever while getting the snout beat out of them - this one should have a fairly good chance of being healthy for a long time with good parts and machine work.
    Have you bought that 572 yet ????
    Tom
  15. dan dibble
    Apr 30, 2004
    30
    collierville TN.
    Very cool. I had a nova with a six in it. Tough mo fo.
    I am going to build the vew motor next winter. Right now Im working on how to inject it that will be as easy as my current system.
    Get a camera and post some pics of this motor you are building.
    Why straight cut gears? Thrust?
    Dan
  16. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    I can't wait to see what the buggy will do with a injected 572 BBC - it's gonna be outragious ! With as much research and attention to detail as you do I am sure it will be a FINE effort.
    I see John has influenced you about pictures of the "School Buss Motor" 292 pictures . I thought about it but I did not think there would be much interest in a straight six motor build up - they just ain't as pretty as the usual cool BBC pic's........
    I thought long and hard about the helical gear and spur gear because of tooth strength but in the end it was thrust that made my descision. Besides a little whine and gear howl sounds cool too .
    Tom
  17. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Dan - How did you like the new 3.0 Atlas case ? Is the power / wheel speed ratio what you thought it would be ?
    I think that 3 to 1 is a great ratio for most applications - if my Blazer acts anything like I think it will, I plan on using 3.1 to 1 most often .
    Tom
