Ordered lift springs.. I'm stoked
Discussion in 'The Garage' started by 78Suburban, May 18, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Well, I've got 4" TC front springs and zero rates on the way. If I use that setup, will I have to lengthen my front driveshaft probably? I've got a th400/203. Will I have to get the zero rate machined into a taper?
    If I order Kert's flip with the 6" shackles, I should be good to go with the rear shaft, right?
    What about the front crossover exhaust pipe on my stock exhaust system, is there any kinda parts store pipe that I can ghetto rig to make my front shaft clear?
    Sorry for all these repeated noob questions, But I'm just so stoked about my lift springs headed toward me in the big brown truck :bow: I know these questions are kinda hard to answer because it varies, but I'm just wondering what kinda experiences people have had with simlar suspension/ tranny/tcase setup, with stock driveshafts. Its a :burb: by the way :p:
    thanks,
    James
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Congrats on becoming a real wheeler. :waytogo:
    With basic aftermarket lift springs your castor should be fine, but hey, YMMV. So no, you shouldn't need a taper on the zero rate.
    You might be able to reuse your old driveshaft. It's easier for the long wheelbase guys to get away with that than it is for everyone else. Shackle flips will actually move your axle forward (very slightly) whereas blocks move it straight down. The longer the driveshaft, the less the angles increase, the less it is stretched. I think you should be fine.
    And for the exhaust...:hack:, then go duals. :D
  3. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    It has to be something ghetto rigged :p:
  4. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    My guess is you will not need to lengthen your front drive shaft with 5" of lift, but your exhaust crossover pipe may hit the driveshaft. With a shackle flip in the rear, your rear driveshaft should be OK as well.
  5. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    You will most likely have to get the front shaft lengthened. Mine only has 3" or so of slip before it fully extends and I am having to get it lengthened with an extended slip.
  6. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    If you want to talk about $$$$$$, then talk about getting a new crosspipe installed. If you want to do it on the cheap, cut that crap out. Buy a set of $18 mufflers. Then find your most reasonable exhaust shop. I had two pipes made at mine. Walked it with all the dimensions, angles, bends, measurements, etc for him. Even had a scaled drawing. The easier you make it for them, the easier they make it on your wallet. He even brought me to the back, and I was able to walk him through it. Out the door, it was $25 for BOTH of my pipes. I threw those in the truck, slapped the mufflers on the end of them, and called it good. A LOT less money than trying to get a new y-pipe made.
  7. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Or if you want ghetto rigged, buy some pipe from your local shop, get one shaped to the approximate shape you need, with a little extra on the ends. Then chop the old one out, and splice in the new one, custom fit as best you can with your angle grinder or sawzall, then weld it in.
  8. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    hey bud good to here your finally gettin a left on the ole burb :D
  9. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I am thinking you are correct because when I had 4" of lift on my truck, the front drive shaft was on the outer limits of not needing to be lengthend, but when I went to 6", it had to lengthend.
  10. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    isn't there some kinda spacer I can use? or is that a bad idea, do I just need to find a relaible shop around here?
    thanks,
    James
  11. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yea James, theres a couple places that make a spacer. I think Skyjacker has one, 1".
  12. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,235
    284
    San Jose, California
    I just installed the 4" TC springs up front and it looks like I need a longer shaft. Although the shaft is a double cardan style shaft (in front) and so I'm guessing it's not stock. After the lift, it only has about 1" of engagement. Is there any guide on how much slip/engagement is needed?
  13. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I do not think there is anybody that makes front driveshaft spacers anymore? I looked through Superlifts cataloug, and there where no spacers offered. I looked at some other vendors of adapter and custom driveshaft stuff, and none of them offer a spacer either. Might have to make your own.
  14. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    so I won't be able to use my stock drive line without getting it lengthened even if I take the zero rate off the front springs? I really thought alot of people just threw 4" lifts on and never touched their driveshafts, especially with a suburban with a long aruse th400/np203.
  15. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    i have the same combo as you (th400/203) but a 6" lift and my driveline was cool because i installed a front 60 to make up for the driveline being too short. had to grind the tabs a little on the cv part, but with a 4" you'll be ok. As far as the exhaust, i had to do the same thing as you so i went to the nearest muffler shop on my lunch break and told the guy there that i wanted it to clear an (invisable) driveline from here to here and he cut the crossover section out and re welded a new piece to clear for 30$. now im wheelin but i hammered my rear driveline almost immediatly because it was too short. So i got one from a th350 truck instead of a th400 truck so the length worked out again plus it had a 1350 instead of 1310 on the rear yoke so i snagged the whole thing with the yoke.
  16. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I thought you ran open pipes? If you do then who cares about a y-pipe just run 2 pipes straight back.
    Or turn downs right off the headers :D
  17. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Stock exhaust.. I had removed the muffler and ran flex hose.. but now I've got a very nice, big, QUIET, stock, free muffler and some flex hose runing after that.
  18. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    I'm a NOOB, and I thought that too, and got lucky. I'm not too sure about my front driveshaft, but am told that it's okay. We'll see. The rear is more than fine.
    Mine's a Jimmy, with 4" front springs, shackle flip rear. Take a good look before you start thinking "throwing 4" on" is just that. I didn't experience anything major, but the bunch of minor things made me wish I had planned better. I am VERY happy though with the finished(?) product.
  19. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    any links on a front driveshaft spacer?
  20. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Try rocky mountain suspension, there's several there.:D
    Edit; Superlift 4310(?)
