Ordering the 'works' need final comments
Discussion in 'Communication (CB | GPS | HAM)' started by 2Dogs, May 20, 2003.
  1. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Ordering the \'works\' need final comments
    Hey All,
    I have decided on the Uniden Grant LT $139.99
    So I need cable and antenna.
    For those that have helped me before - thanks! I need a final concensus on the antenna. I will be mounting it on the rear bed area. Needs to be flexible and tough. I was thinking firestik because it would be easy to mount. Y'all have suggested Wilson's, 102" whips, sounds better but I don't think the Wilson will mount because of the wider base.
    I don't know if I can find a 102" whip either (by this weekend). And I worry about that getting in the way (trees, people, low flying aircraft, etc....).
    So, any comments? Like a firestik alternative? Or a different way to mount Wilson's?
    Thanks again!!!
  2. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Re: Ordering the \'works\' need final comments
    You sound like you have it all pretty well figured out. Since you're a little confused on using Wilson's you might want to look into getting a Wilson trucker 2000 or 5000. It mounts the same way a 102" whip or a firestick would.
    [​IMG] [​IMG]
    Wilson 2000 at Pacetronics Wilson trucker 5000 at Pacetronics
    Wilson also has the "Silverload" antenna which is much like a firestick.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Personally, I don't belive anything out preforms a 102" stainless steel whip. Call your local Radio Shack, they usely carry it. If you get the heavy duty (pot belly) spring with it, you need not worry about tree limbs.
  4. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    I will second Z3PR's recommendation on the 102s. I prefer the fiberglass whips over the steel as it's not so "floppy" but I will admit they are not as durable as the steel. Get a 102, you will hear better. If you absolutly cannot live with the length, get the Wilson Trucker style.
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I didn't get the CB for this weekend - 6 vehicles and I didn't have a CB.... /forums/images/graemlins/angryfire.gif
    Now I can plan better at least....
    So the 102" whip will work ok with an SSB radio like the Uniden Grant LT? I know you guys answered this but just double checking /forums/images/graemlins/grin.gif
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Yeap, 102 works great on side band. Like I said befor, in my personal opinion, NOTHING out-preforms a stainless steel 102 inch antenna for 11 meter (CB) for mobile use.
