ORD's new High Clearance HD Engine Crossmember!!!
Discussion in 'Vendor Forum' started by Stephen, Dec 15, 2005.
  1. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    Here it is:
    No more cracks, no more clearance problems, and stiffens the frame up. Provides easy access to the motor mount bolts and won't limit compression travel.
    ORD CATALOG PAGE HERE
  2. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    That is sweet!!! Nice work for Steve and the ORD crew once again. :waytogo:
    Now....what are the chances you can adapt that and the tranny crossmember to bolt in a belly skid?:thinking:
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    That is sweet lookin. Will it also work with a 7qt oil pan tho?
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Nice...... and just in time.... I am doing my crossover right now and I am running into clearance issues. If I have enough money left over after Christmas I will order one.
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Can you do one for an LS1 motor?? :D
  6. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    will this work for 250 I6 engine?????
  7. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    Belly (oil pan) skid? We've done some custom stuff on our buggies that integrates the engine crossmember so it definitely works, we use bolt flanges of some sort to bolt to the engine and t-case x-members. I don't see integrating a bolt on system anytime soon due to variations in exhaust systems, crossmember locations, etc, but it would be pretty simple to do on a custom basis.
    Aftermarket oilpans? Shouldn't be a problem within reason. Typically the deep sump pans use a stock profile under the front and just add a deeper sump. I ran a deep pan on my 383 that the original crossmember was built around then we dropped the big block in with a moroso 7qt. Obviously neither was an issue.
    LS1? We'll sell you the brackets to build your own? You're going to have custom motor mounts and a much different pan profile so all bets are off with that one. It might work but then again it might not.
  8. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    250-6? Probably OK but given that I've never even seen a truck with a 6 cyl we haven't tried it out. I would guess that since the small block is a direct swap, our crossmember would work but once again we'd have to try it to see. If you want to try it, you pay to ship it there, if it doesn't work, we'll pay to ship it back.
  9. CK5
    May 19, 1999
    21,627
    704
    CO
    Sweet, I have seen these in person and will have one installed under the UAV, the one I currently use comes in contact with my ARB line under suspension compression, that and it was a major pain to gain access to the mounting bolts.
    This is awesome especially for those of us with smaller lifts and hi-steer.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Very nice. :bow:
  11. CK5
    May 19, 1999
    21,627
    704
    CO
    Another pic from there site
  12. the beast
    Oct 15, 2003
    535
    Providence, RI
    Yes an oil pan skid. We'll have to chat when I get ready to order one.
  13. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    Typically the oil and trans pans are not too vulnerable on a GM since the motor's so far forward. But when you're wallerin around, stuff happens. With Wally's axle pushed forward about 7", the trans/motor skid is a pretty important item.
  14. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Nice, another item from ORD that I'll have to hide from the wife...:eek1:
  15. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Holy crap, now i need to start saving money again.
  16. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Any pics of the crossmember in a big block truck w/ headers (maybe Wally)? I'm curious to know if there might be any interference problems since the crossmember is moved rearward some.
    Do you have any measurements for the back of the crossmember to the front of a big block oil pan sump? I use a larger aftermarket pan also.
    Last question; I will be using your motor mounts, I assume the motor will not sit lower than stock right?
  17. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Why hide it? Just wrap it up and put her name on it under the tree :D :haha:
  18. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Nice work you guys are filling the gap now that moo is closed, how bout some rear shock relocation kits?:D
  19. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    I think it's safe to say we will never relocate the shocks to the center of the truck. We've played around with some more effective mounting locations though and some of that might bear fruit in the future.
    I've had good luck before with: "If it breaks it could leave us stranded" This works especially well if she goes with you a lot.
    Here's a pic that shows the back tube of the crossmember that was in wally, there's really no problems with any headers since the tubes are both under the factory frame boxes that the motor mounts bolt to. It also stays forward from the front of the sump for most pans with a stock-ish profile. This pic (and the others on the custom rigs page) have our motor mounts installed, motor position should be pretty close to stock, they're built around a set of factory mounts.
  20. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    dang that is nice, great work!
    good price too!
