ORD's shackle flip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SnoMan, Apr 3, 2000.
  1. SnoMan
    SnoMan Registered Member
    Mar 24, 2000
    20
    cook county, Il
    ORD\'s shackle flip
    I'm thinking of ordering Off Road Designs shackle flip but not sure yet. Anybody have the kit and can share pro's and cons?? 3rd Battalion
  2. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Re: ORD\'s shackle flip
    I bought a kit from ord about two years ago. I wish I would have done it sooner. It got rid of the blocks and now flexes alot better, not to mention rides better. I would recommend it to anyone instead of new springs in the rear. The only drawback I can think of is the labor involved (dropping the tank and grinding off the old shackles). I just put a flip on my buds 72 blazer while swapping axles. No complaints so far. The shackle filp was covered in some mags a while back. You might find more detailed info there.
    BIGJ
  3. cp87jimmy
    cp87jimmy Registered Member
    99
    Frisco,TX
    To be honest with you I can't at this time think of any cons. I just installed mine 3 weeks ago. The install is a little tough with the gas tank and all. Once you get past that it's really pretty easy. I also got the add-a-leaf for my rear springs. It really makes a difference in the stock springs. It also gives you about 1 more inch of lift. The best thing I can say about it is, NO LIFT BLOCKS!!! The ride is not as harsh as a spring lift either. That was important to me since mine is a daily driver. Hope this helps. Let me know if you have any other specific ?'s about the product. Chris
    By the way, Stephen and his dad at ORD are two of the nicest and helpful guys you'll ever deal with.
    So addicted it's not EVEN funny!!!!
  4. SnoMan
    Mar 24, 2000
    20
    cook county, Il
    Thanks for the info, my 88 is my daily driver, also goin with me to NMU so it'll be on the highway to the UP and back to chicago. I'm gonna blow a good chuck of money gettin nice shocks too. thanks!! 3rd Battalion
  5. Rockblazer
    Rockblazer 1/2 ton status
    Feb 18, 2000
    114
    South Dakota
    Ok here is my 2 cents! First of all, with the kit you end up with a shackle that is straight up and down, and an axle moved forward about an inch. My question is first of all how do you get more flex? Other than the spring arching more as it droops the shackle does nothing. Second, how is the ride any better with the shackle mounted straight up and down. Third, it moves the axle forward?? I think its a good attempt to eliminate blocks but there must be better out there! I do like the idea of using stock flat springs and no blocks though! Just for comparision, I ramp at 972 with 4" blocks in the rear. Hmmmmm... what to do! Good luck!
    Todd
  6. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
  7. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    I have the ORD flip w/2" springs.It rides great.My shackles lay back about 1 1/2" maybe because of the new springs. Before this i had the free flip but the shackle will hit the mount and limit movement.At least it did in mine.
  8. BIGJ
    896
    Central Arkansas
    To be more specific it rode better than with the 4 inch springs I had before the flip. First I had blocks, then 4 inch springs, then the flip. The old bushings in the shackle were bad rusted and pretty much fused to the bolt and overtightened WAY TOO MUCH!! Therefore they didn't move much in the mount. New polyurethane's probably helped out too. RTI went from 720 to 934 with the addition of the flip and new bushings when compared to blocks and factory hangar.
    BIGJ
  9. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    If you buy ORD's shackle flip, read my site, there is a link above, it will describe how to install ORD's system with out removing the tank!
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  10. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    How is the Axle wrap after the swap? Did it improve on the take off?
    C'moe
    <font color=black>the blazer is "Back in Black"
