Oriface tube pop quiz
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crashfirepm53, Jul 14, 2004.
  1. crashfirepm53
    crashfirepm53 Registered Member
    Mar 14, 2004
    62
    florida
    Any reason why my 91 burb has a Blue Ford A/c oriface tube for the front A/C?? The Gm white/black tube wasn't even close to fitting.Very different.Also where is the rear A/C oriface tube at??
  2. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Possibily after market ac conversion? ID ont know about the rear orfice........if there is one.
  3. crashfirepm53
    Mar 14, 2004
    62
    florida
    Well Auto zone sells a rear oriface.I've taken every connection apart pretty much and no rear oriface.A/c is Factory.The rear lines o-rings are still black.I'd guess they are the old ones.So much for a quality conversion job.Now the bad news the small rear line where goes thru the rear floorboard unfort. was corroded and the line snapped off at the fitting.Does the whole line need replacing or can It be fixed?
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Do a search here, it's been asked before and someone posed an exploded view that shows where it is.
    /forums/images/graemlins/dunno.gif
  5. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I always thought it was in the low pressure line at the junction on the firewall inside the tube /forums/images/graemlins/thinking.gif it's been awhile since I replaced one, so I might be wrong.
  6. crashfirepm53
    Mar 14, 2004
    62
    florida
    The exploded view I can only see one listed.That was the front that The Blue Ford tube went in.You can look under "oriface" in the search.
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    I heard that the Blue Ford tube works better for R-134a. The white GM tube is for R-12. 134 likes a slightly smaller tube.
    Since you're tearing into it, you should drop in a VOV. AC Source should have it for any application.
  8. crashfirepm53
    Mar 14, 2004
    62
    florida
    Well I'm in Fl and it's hotter than hell so no time to wait.apparently there is no rear orifice tube anywhere that I can find.I went to the junkyard to replace the high pressure line and of course they were all cut.I paid $10.00 for one that will give me plenty of straight area to couple them together.Can I use brass couplers with the compression fittings?No one has anything else.
  9. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    As far as I can tell, the rear AC works off of an expansion valve right at the rear evaporator (in the overhead). We own a 77, 78 and an 84 and all those subs are the same.
  10. crashfirepm53
    Mar 14, 2004
    62
    florida
    I used a compression coupler no leaks.Looks good.Weird tho.At 2 parts stores the list the expansion valve as a orifice tube.The rear system does have a expansion valve not an orifice tube.
