Orifice tube problems
Discussion in 'The Garage' started by Impex, Sep 4, 2002.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    Decided to go back to R12 after converting to R134a (Factory Air rebuilt compressor enough said...hehehe) Back when i did the R134a i bought a evaporator from a j-yard (had to buy all the new parts after previous owner stripped stock a/c out) well when i was putting the orifice tube in i had lots of trouble getting it to go all the way in, the evap. line was sorta bent but got it to go all the way in. Now (after flushing the whole system and installing a new o-tube) i tried fixing bent line and i think i messed it up worse cause the orifice tube only goes in like 1" and that's it, & i ruined the o-tube trying to get it in. So after all of this can i cut off the bad section of the tubing and re-flare it? i had a custom high side hose made & i do have enough slack in the hose to reach.
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Autozone has orifice replacement kits that you can reflare the line and put in your tube back it. They are behine the counter, so good luck explaining your problem to the moron behind the counter. They are labeled for GM vehicles I believe, they are not in the computer I don't think.
    Blake
