original spring pads on 14 bolt, cast or mild steel or ????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by icehole, Apr 10, 2002.
  1. icehole
    icehole Registered Member
    Apr 2, 2002
    10
    sterling hgts. MI.
    im thinking of reusing these spring pads but need to know what type of steel they are for welding purposes, also does anyone sell the solid type like factory??
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Depends on the year of the axle, not sure what years they changed. They were either cast or stamped mild steel.
  3. icehole
    Apr 2, 2002
    10
    sterling hgts. MI.
    i think its a 78 14 bolt...anyone else???
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    99% sure that the spring pads are mild steel. Along with the tubes. The housing should be the only part that is cast. As far as welding goes, I'd use a MIG welder. Or if all ya have is a stick welder that is capable of DC current, use 7018.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Well...they are either stamped steel or cast...it should ba easy to tell the difference. I have a 77 and they were cast iron and that is most likely what you have. I made some new ones out of 2.5" .25" wall square tube (because no one that would weld them on for free would touch the cast). You can also buy new stamped ones but they just look wimpy for such a tough axle.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have always thought the perches were cast pieces.
    Be aware of the change in the perches on the 14FF's. All 14FF's up to '84 have the cast perches, and in '85, they changed the perches to the stamped steel, exactly like the 10 and 12 bolt rear axles. /forums/images/icons/wink.gif
  7. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Just an FYI Wes
    My 14ff is out of an '85 1-ton & has the deep-pocketed spring pads; the ones I'm guessing are cast. Either way; they're not like the ones on my old 10-bolts
  8. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
  9. Brian 89KBlazer
    779
    Ontario, Canada
    Hey Peter
    You have email! /forums/images/icons/smile.gif
    Sent you a couple pics of my 14ff. Let me know which ones I have will ya?? /forums/images/icons/wink.gif
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Send me pics, too. I can tell you which you have. /forums/images/icons/wink.gif
    I still stand by the stamped steel perches in '85 theory.
  11. can someone explain to me the difference between cast, mild steel and stamped steel? which is stronger, why and why cast is hard to weld on? thanks
  12. Brian 89KBlazer
    779
    Ontario, Canada
    OK Wes, they're on their way but their not the best /forums/images/icons/shocked.gif In the meantime; your should be able to make them out.
  13. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Mild and stamped steel are the same thing. Easy to weld and cheap to make. The cast perches shouldn't be a big deal either...I'm pretty sure they are ductile cast. If you look you'll see they are welded from the factory. I'd prefer the ductile cast perches as they would be a bit stronger. Ductile cast doesn't require any real special welding procedures or any special rods. We used to use ductile cast for some oddball parts at a place I used to work at. We used MIG on em...
    FYI Jason normal cast iron requires special welding rod and procedures to weld properly (T-case adaptor would be a good example)
    Rene
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    Brian, I got your e-mail.
    Your pics show the 14FF you have, to have the cast perches. Your axle is the '84 or older one.
    The stamped steel perches look like the 10, 12 and 14(SF) bolt axles. The 14FF stamped steel perches are a lot thicker though.
    10 and 12 bolt perches appear to be about 1/4" thick. 14FF perches appear about 3/8" thick. You can see the difference.
    My '85 K30 has these stamped steel perches. I can get pics if anyone would care to see them. /forums/images/icons/wink.gif
  15. Brian 89KBlazer
    779
    Ontario, Canada
    Thanks Wes
    I can't argue on the year cause I didn't actually pull it from a truck. It was shipped to me rebuilt with "1985" on the invoice & tag. Just going by that but that doesn't mean you're wrong! /forums/images/icons/smile.gif Hell! I'm happy just to have a 14ff!! /forums/images/icons/tongue.gif/forums/images/icons/laugh.gif
    Thanks again for the help
  16. thatK30guy
    Jan 12, 2001
    32,076
    55
    No problem. /forums/images/icons/wink.gif No big deal either. Like you said, just be happy you have the 14FF! /forums/images/icons/wink.gif /forums/images/icons/cool.gif
    IMO, the spring perches are the least of your worries with these axles. I have not seen nor heard of one stamped steel perch going bad on any 14FF.
    Nor have I heard of any other problems with these rears, too. /forums/images/icons/cool.gif
  17. shoeless
    shoeless Registered Member
    Nov 1, 2001
    99
    N/A
  18. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Interesting...I guess I could have re-used the stock cast ones...I like the ones that I made though and was able to move the axle back 1" in the process. Oh well...live and learn.
  19. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    If anybody is interested, I have spring pads for 14 bolt's. I am also in the process of making them for the 1/2 ton axles as well. They are made of mild steel and are solid. These have to be the strongest looking spring pads that I have ever seen. They are machined to place the leaf spring aprox. 1 inch above the axle tube. I can also drill them in the center, 1", or 1 1/2" back so that they can be used to relocate the axle slightly. If anybody is interested in a set, PM me. The price for now is 40.00 a pair plus shipping. These things weigh in at about 5 lbs. apiece, very stout. I will post some pics of them as soon as I can.
  20. Brian 89KBlazer
    779
    Ontario, Canada
    OK Wes
    Just a little update to say "oops" /forums/images/icons/blush.gif & to re-verify that you've got your facts straight. /forums/images/icons/wink.gif The invoice says both axles are from a SRW '85 1-ton while the tag on the 14ff said 1980 when I double checked last night! /forums/images/icons/tongue.gif
    Thanks again & you remain "THE" K30 man! LOL! /forums/images/icons/laugh.gif
