Other causes of "DIESELING" or "RUN-ON"?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, May 15, 2003.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Other causes of \"DIESELING\" or \"RUN-ON\"?????
    I know that if your timing gets over-advanced your motor will "run-on" or "diesel" after you shut it off.
    IS there anyhting else that will cause this?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: Other causes of \"DIESELING\" or \"RUN-ON\"?????
    intake gasket leaking did it to mine /forums/images/graemlins/shocked.gif
  3. dyeager535
    26,977
    Engine too hot, and if there is a throttle "kicker", it may be working incorrectly. Happened on my 305 with AC.
    Throttle kicker sits on the front drivers side of the carb, and pushes the throttle open slightly under certain circumstances.
  4. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    or....too much backpressure. ive experienced this a few times. i went from open headers to 2" pipes all the way back on the 454 and it killed it and made it diesel like a b*tch.
    NITRO
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    too high an idle can do it. My high idle cam wouldn't kick off so I bypassed the choke and it doesn't do it anymore. Takes a little to get her started on a cold morning but it just never sounded good to hear my brand new motor with 1500 miles dieseling away.
  6. Can Can
    15,552
    136
    That makes the most sense so far. I did bump my idle up quite a bit while trying to solve my earlier boggy start problems and I've been too lazy to turn it down. /forums/images/graemlins/crazy.gif
    Thanks for the input, brothers!!! /forums/images/graemlins/thumb.gif
