other heads vs. vortec
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Nov 5, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I know the vortecs are great right outta the box, but Im going with the TBI setup and was wondering since I'd have to by the gold plated intake manifold for this, what are some other heads that are comparable to the vortecs?
    I have read up on the World S/R Torquers and the sportsman II's. They appear to be about the same price as the vortecs along with the special intake. So I mjust weighing my options hear fellas.
    Any info?
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    ya know what I debated this exactly issue... when it comes right down to it you can buy the heads and the intake for the same price or cheaper then you could buy any other heads...
    I'd think this would still be the best bang for the buck!
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Thats what Im thinking. But I dont have enough knowledge to really make a sound decision on my own in this particular field.
    Also, Im wondering weather or not I should replace my stock intake manifold anyway, if so I might as well got with the vortec and get the vortec tbi intake and take out 2 birds with one stone.
  4. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I've run both the Vortecs and the S/R Torquers on back to back 350's.... The Vortecs are better!
    Marv
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Thanks for the input marv
    Ok, keep the info coming people.
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    you know what after having just having done a major job on my engine the only part that is the same as when I got my k5 is the starter, and the t-case... it ended up costing me a lot more money then I anticipated... (I'm sure there aren't too many cases that are quite like mine).
    I'd recommend 2 things; 1 it is a lot cheaper to go stock... why do you want the extra power (i.e. how is this thing gonna be used, does it really need it). remember the more power you have the more parts you are going to break...
    when I do the engine in Insane Ewok (off-road k5) (which won't be too long from now) I am going to go all stock except for a cam, and possibly an intake.
    if this is gonna be a trail rig rebuild the engine if it needs it, and otherwise leave it along, and put some $$$ into some off-road stuff. just my $0.02...
  7. MRBIGBLOCK
    MRBIGBLOCK 1/2 ton status
    Jun 25, 2001
    472
    paragould arkansas
    hey dude u can buy the heads from scoggins-dickey that have been drilled for non vortec intakes.
  8. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea, but I don't think they have been drilled for TBI intakes...
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Huh? Not drilled for TBI intakes? No offense but, to my knowledge there are 2 different patterns, Vortec (1 bolt each corner, straight up) and pre-Vortec (multiple bolts at an angle). Other than the Odd-ball Vortec TBI intake that has recently become available, all TBI intakes should fit the old pattern.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  10. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Russ,
    The center bolts on the TBI intakes were at different angles than the outer bolts, unlike the pre '86 heads. There are three different intake mounting styles for the small block chevy.
    '85 K5 : Run it til it breaks, then fix it and go again!
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Cool, learn something new every day. I thought there were only two. So what does that mean for guys doing a TBI swap? I thought a TBI swap was just "bolt on" affair for carb'd engines. I guess it was a good thing I got my TBI 350 complete rather than doing a swap. I would have been in for a nasty surprise. [​IMG]
    Russ
  12. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    You can elongate the center bolt holes on the TBI intake to make it work with the early style head, but it is a pain in the butt.
  13. K5_73
    K5_73 Registered Member
    Feb 5, 2001
    53
    Wichita, Kansas
    Well, I kind of have a different opinion, but I guess that's why you posted. I just put my 383 together last weekend, and after many problems in getting my stock 993 castings worked on (among other problems), I decided to go with the cast iron Sportsman II's. Many things factored into this, including the fact that my buddy ('73 K5) upgraded to Vortec's after pulling some rocker studs on his stock heads. He gave me a good deal on his Performer intake, and Crane roller tip rockers, so, for me, the overall price was better, and the potential for more power was also there. The Vortecs are a great head for torque and mid range power, but from what I hear, they run outta steam on the high end, but that really doesn't matter in our rigs. The Sportmans support up to about 450hp outta the box, and with some porting, can support up to 650hp. They were only 25 bucks more per head than the Torquers (about 800 per pair assembled), and they have bigger valves, and under 3000 rpm's they flow like a 170cc head, but above that, they pick up, and flow the 200cc. All I can say is that if you want to look at my profile for specifics, it seems to be working REALLY well for me, and has some serious pull, just ask '73 K5. In the end I would say that you need to think hard about what you're going to be doing with your rig, and your checkbook will also be a big factor. Good luck,I hope this helps.
    Stupid hurts
  14. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Be carefull looking at adds. The Vortecs are around 400 bucks a <font color=red>PAIR</font color=red> where the others, including world have some tiny little print that says <font color=red>each</font color=red>. With the Vortecs allow another 100 bucks for self guided rockers too. Read the adds very carefully.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=) [​IMG]
    <a target="_blank" href=http://community.webshots.com/user/chevyracing>http://community.webshots.com/user/chevyracing</a>
  15. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I got the rockers from sdpc2000.com, and it was like $63... including shipping so they aren't quite as bad as $100... I think pace parts has the best price on the vortecs, but I'm not sure what your membership discount is with sdpc is so you might try there for both of them...
  16. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Well after readying the TBI upgrades article in the Petersons last night Im sorta leary about the 383 now. It said that Hot Rod built a 383 with a stock TBI with SPortsman II heads and they said that they couldn't even get it close to running right without a custon chip from Turbocity and even then from the way the writer put it it still had problems. So now I need to find me the Jan. 2000 issue of Hot Rod Magazine to get more details. Does anyone have this article?
  17. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    try calling fastchip... I've been pretty impressed with what they did for me (350 w/ vortecs, gm perf intake, 454 TBI etc.)
  18. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    MUDNUTT just built a 350 with Vortec heads. Look at my link in my signature and you can see some of the pics. Anyway he put it in his 79 Blazer and it screams!! (not just because of the gear drive either) I honestly think it will outrun my 383. It will be interesting on the 25th to see what happens because we have the same exact setup (465, 205, 3.73 gears, 33x12.5x15) but mine is in a 72 and his is in a 79.
  19. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Thats what Im starting to lean towards. Racing did you see my PM?
  20. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Basically I think a lot comes down to what can and can't be done with the chip. I have heard of a couple guys running 383's with TBI and no real hassles. You may want to give BlazinOR a pm and see if you can't get the # for the guy who did his 406 tpi setup.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
