Our Loss, Your Gain!! Silly Strong Spring Perches!!
Discussion in 'Vendor Forum' started by Gravel Maker, Aug 5, 2006.
  1. Gravel Maker
    Gravel Maker 1/2 ton status Vendor
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    It seems the laser operator was asleep at the wheel this week, first he wasted 2 sheets of 1/2" plate ($$) :eek1: and then made something like these.....
    Actually they were exactly like these with 1 minor exception! And do I need to remind you that we are the overkill guys! The exception is that he cut from 3/8" rather than 1/4"!!!:o
    Now we like strong but these are Silly Strong However, there is no effect on their performance, but enough beef that we will offer about a jillion year guarantee on them!
    We are going to sell them off at a very fair price of $25 a pair, our normal price is $28 on them so they are not free but the normal ones are only 1/4" thick. So, if you want Silly Strong pick up a few pair!
    They were made in the 2 1/2" and 2 3/4" widths and we have 100 pair of each.....And don't forget the CK510 Discount either, that makes them $22.50 a pair!!
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Can you cut the extra thick ones for a 4" axle tube?
  3. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    These could be modified to fit, it would take about 15-20 minutes each with a grinder, less with a plasma cutter.
  4. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    By the way these are selling.....
    I might think you prefer 3/8" perches? I think 1/4" is thick enough as long as they aren't trying to lift the vehicle too. Collapse seems to occur on the lift style 10 to 1 over our style. Give me your ideas on that, it isn't a problem to make them like this all the time if that is what you really want.:D
  5. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    1/4 is min. thickness, 5/16 is great, 3/8 is overkill. when I buy a set from you I WANT the 3/8's ones :D . as soon as I get my first check from my soon to start new job I will be ordering a D60 cover and a set of pearches. I dont really need a set of pearches but for that price and beef why not.
    a solid set of pearches I made to show someone hear it can be done and how to do it at home with minimum equipment are REALLY, REALLY overkill and not necessary but I proved my point that it can be done at home.
    even using tube and doing it at home is too much trouble compared to buying yours though. as I said before I dig your products and your prices Dan.
  6. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    Thanks, the demand has been so high for these.....
    We may continue to offer them after the sale.....I never said there was anything wrong with beef!
  7. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    Just updated with the correct pics.....
    And a stock update, we have 22 pair of the 2.5" left and a little more than that of the 2.75"......How to make spring perches, they are either bent or welded, bent over a mandrel will give a round shape and diminish the surface contact with the spring, bent on a CNC brake will Fold the steel for the most contact available. We fold with a CNC Brake. If you have 100% contact they are too wide and the spring will be free to pivot on the pin, you want springs to fit, they are not 1 size fits all!:D
    Sale ends the 18th.....
  8. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    which part # do I order off the www site to get the silly thick / sale priced ones? which of these are currently on sale: sp3? sp7? sp2? these will be going on a ff14b... forget the exact diameter of the tubes on 'em... 2.75" wide would be best, but 2.5 could work too...
    lemme know so I can place an order. :)
    j
  9. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    Look in the specials section.....the SP2.....
    Is the part # for the 2.75" wide ones.....
