out of alignment after tire rotation?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Feb 20, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I got my tires rotated a few weeks ago, and ever since, my alignment has been off. Is this because of the wear patterns? I waited too long to rotate them...I think about 8K. This will go away soon, right?
    90K5
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Very common for tires to cause a pull. Your alighnment did noyt change, just the tires. Chances are that one tire is worn more-so than the other, or slightly shorter than the other. Try to cross the two front tires (left to right, right to left) and redrive- Also check air pressure.
    <font color=white>.</font color=white>Eric
    <font color=white>.</font color=white>Twizted
  3. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    dont worry at your next rotation it will cure itself, but seriously it might be air pressure or they were wearing funny im sure it just needs a bit of an adjustment
    <a target="_blank" href=http://www.myk5.com/gallery/>SoCal Big Dawgs</a>
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Air pressure is even all across...it was perfect beofore the rotation...I'll try switching left to right. Thanks
    90K5
