Out of commision for awhile-update- problem found- Dammit Bubba
Discussion in 'Rocky Mountain Region' started by FWP, Oct 11, 2006.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    You guys have fun wheelin. I'll be doing a clutch, hydraulics/ pilot bearing, input shaft, whatever- in the Cummins:( . Started f'n up in Moab, it's gettin worse. Driving it today absolutely sucked. I need to fix it now.
    Should be back to towing duty within 3 weeks.
    Found the real problem, 4500, Oh Crap- Input bearing or mainshaft endplay issue:doah: Thanks goes to Rene for the advice/ experience.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    That sucks. Clutches are not cheap in these truck either to do them right unless your are SOOOOOOOOO MONEY. :D I am dreading that day in my truck cause doing it right means Southbend or similar. Could be worse though you could have the auto and be looking at $5000 to do it right instead of $1200-1800 to do it right.
    Good thing you got 2 yellow Cheby's to fall back on for a DD.
    Harley
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    That sucks . I think I may drag Michelle for a Saturday or Sunday visit next week or two to say hey and see what ya up to . Who know maybe I will have the winch mounted and can grab your cable :thumb:
    Need help call me !!
  4. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Pauly....
    You should have more respect for your wife...! :D
    Marv
  5. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Sorry to hear it #3.....
    Flippin' Dodges... :D
    Marv
  6. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I know that guy...!
    Marv
  7. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Sounds like a good opportunity to put an aftermarket clutch in it and turn the power up... Too bad they cost so damn much.
  8. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    its only money..you can always make more:D
  9. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    It's bombed. Hence the short lived stock clutch.
  10. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Rumor has it that the truck went up and down Lion's Back. Could that be a problem???????????????
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Yup- this is what caused it... Damn you to hell!!!
  12. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Which clutch you going with Fred? Same setup as Rob? Someday in future I am sure I will be needing to do the same thing and step up in the clutch world. It all depends on how heavy this Smarty is and how soon I get some injectors & exhaust.:D
    Harley
  13. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
  14. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    It was good talking to you Fred, I hope you get that thing back together real soon. At least you have that NV4500 book to help you out...
    Personally I'd replace the input bearing and the little roller bearing that sits in the recess of the input and pilots the mainshaft...then see how the end play is. I suspect that should take care of the problem without getting too deep or spendy into things. The only sucky part would be if you ended up having more than the allowable endplay after swapping the new input bearing on and had to mess with the shim pack at the back end of the tranny. That mainshaft nut is a real bear to remove and re-torque. The only good from that would be getting a first hand look at the 5th gear, and whther or not there is any appreciable fretting on the mainshaft there (eminent signs of 5th gear failure)
    Rene
