Outlaw Octane Booster
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Slayer, Nov 19, 2001.
  1. Slayer
    Slayer 1/2 ton status
    Oct 17, 2001
    225
    Eastern Colorado, jokingly referred to as Western
    <font color=green> I used to use 104+ Octane Booster(in motorcycles), as it was the only product available overseas, but all it ever seemed to do was make my plugs red. Now I am practically forced to use octane booster in every tankfull of gas(so I can keep the timing advanced) and the 104+ stuff again does NOTHING.
    The guy at Checker suggested Outlaw Octane Booster, and it seems to work. Not only work, BUT, it's half the price of 104+.
    Could it be, I have found a product that actually works, and is half the price of the competition??????
    Is that possible in this politically correct world????????
    Somehow it seems like that's wrong, as nothing works good and is cheaper than the competition.
    Anyone have any recommendations for other octane booster products readily available?</font color=green>
    <font color=blue>I don't know everything, I just think that I do.............</font color=blue>[​IMG]
  2. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    Get a copy of the December 2001 issue of Hot Rod Magazine. There is an article about octane boosters starting on page 38.
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  3. xplosuv
    xplosuv 1/2 ton status
    Mar 9, 2001
    515
    Sacramento, CA
    I've heard from the older gear heads that you can add 1 quart of rubbing alcohol to 15 gallons of gas.? anyone heard that one before?
    If you cant go over it...GO THROUGH IT !!! <a target="_blank" href=http://www.CaliforniaK5Krawlers.com>www.CaliforniaK5Krawlers.com</a>
    75 Jimmy 11" lift with 40's
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I use Outlaw products too . I use the octaine boost in my boat and the injector cleaner in my vehicles. Its good stuff. It seems to bure very clean without those red deposits.
    Yes you can use rubbing alcohol (methal alcohol]) in gas. It will help if you have a detonation problem or pinging. Also puting about a quart in 5 gals of gas in a enpty tank will usually get you running clean enough to get past the smog check.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
  5. dyeager535
    26,979
    Yeah, but usually to make the vehicle run clean enough to pass emissions. It's more like 25% alcohol that you run.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    "Dry Gas" is mostly just rubbing alcohol
    <font color=green>There's nothing like the smell of a rich V-8 in the morning...</font color=green>
