output flange
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James, Jul 26, 2000.
  1. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    Can anyone tell me where to find(besides the dealer) the tool needed to hold the output flange from the t-case. Trying to replace the output flange which connects the t-case to driveshaft ujoints. Need to keep the output flange from turning while taking off retaining nut. Also what is the best puller to use on the flange? 73k5 with np203 tcase
    thanks
    James
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    To remove that big nut, just put the vehicle in gear/park, and or engage the front wheels to the axle.
    This will work if still mounted in vehicle.
    If not still in vehicle, see if you can attach either the front or rear driveshaft, and try to brace it, or put on a vise
    Good luck
    P.S. Miller tool I think makes that flange holder
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Do not turn it against the gears as suggested above. A big pipe wrench works perfect for this. You will not need a puller to get the yoke off.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  4. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Turning aginst the gear is not the best but it is done most of the time. An impact works better that anything. And yes a good flange or yoke may need to be helped off with a puller. If fitting a new one to a new output/input shaft you may find that heating the part in the oven at 200 deg. will make it slip right on. Its always a good thought to take your time and find or make a tool to hold something. Try to stop short of hurting the part with the sharp jaws of a pipe wrench or such.
    I understand the jeep thing I drive a BLAZER!!
    Ken
  5. James
    Jun 22, 2000
    179
    Castaic, Ca
    Thanks for the info guys. Was originally going to use pipe wrench. Did not know if that would cause problems.
  6. Executioner
    Feb 22, 2000
    1,530
    If the gears, and chain can't take about 150lbs./ft. of torque, then something in side the t-case is not right.
  7. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I made my own tool from a 6' section of bar stock. cut 8" off end. drilled 2 holes in each part so I could clamp around the yoke. on the flat side. tightened bolts and let the bar rest on the ground. used that to hold yoke. had a very stubborn pinion nut!!
    your right. I don't understand the jeep thing!
