output shaft angle?
Discussion in 'The Garage' started by Rusty68, Mar 19, 2003.
  1. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    I just swapped in a new cross member because mine was all beat to death. Anyways, what should be the angle the transfercase output should be at? I have not checked it with a gauge since I need to go buy one, but it looks like mine is tilting upward a bit. should I shim down the crossmember a bit to bring the angle back into play? What about the torqe on the mount bolts? I just cranked down on them. I do know that the output to pinion angle has to be within 2 degrees to keep away vibes. I searched and could not find any info. Thanks for any help.
  2. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    hmm, nobody running a transfer case here?? /forums/images/graemlins/smile.gif Common HELP!
