Output shaft on a 700 r-4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by walt88, Jan 2, 2001.
  1. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    Is the output shaft on a 700 r-4 fomr a 2wd truck, the same as a 4wd blazer 700? If not, can you swap output shafts?
    Keep the shiny side up, and the greasy side down.
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I think they are the same spline count, but I think the length is different. Think the 4x4 shaft will be shorter. Not real sure. You can e-mail 700r4.com, they will be able to tell you for sure.
    Will work for parts, beer and sex.
    90 Jimi,350/700R4/241/10bolts/3.73's/33's/4"
    <A target="_blank" HREF=http://mccordhouse.freeservers.com>http://mccordhouse.freeservers.com</A>
  3. walt88
    May 24, 2000
    430
    Monmouth County, NJ
    Thanks Alot!
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    the whole shaf thas to be removed to make a 2wd tranny work as a 4wd tranny. which means the whole trans has to be disassembled, then reassembled....js
