output shaft?
Discussion in 'The Garage' started by 82_k5, Apr 17, 2006.
  1. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    I have a 700r4/208. My tranny is bad and I have a line on a 700 that had a 205 behind it. Would this fit with my 208 or would I have to get an adaptor? If I did get an adaptor would I be able to use my driveshafts? If I bought the 205 too and just used that combo could I use my original driveshafts? I've searched and haven't been able to find what I'm looking for. Thanks a lot. BTW, the 700r4/205 combo also came out of a blazer.
  2. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    you will need either a custom adapter (they were never a factory pair), or a spacer (about 1.5") and use the 205 adapter, or change your existing adapter to fit the bolt pattern of the 205. you can also change your output shaft of the 700r4 to the short one, which is probably what the combo you found already has. no matter what you do you will need a new rear driveshaft because a 205 has a fixed yoke and a 208 obviously doesnt. not sure about the front.
  3. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Not all np 205's have a fixed rear yoke.
  4. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    true, but almost all do. i gave it the benifit of doubt.
  5. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    A np 208 front drive shaft has a flange, the np 205 probabily has a yoke.
