outside mirror removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by delta9blazer, Oct 23, 2000.
  1. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    89 with the vaguely triangular-shaped mount. do they bolt from the inside of the door? my POS manual doesn't say dick about it. has two pictures, neither one of which look like mine.
    <font color=purple>delta9blazer</font color=purple>
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Should be a screw at the bottom of the mirror base on the outside. This allows you to take the cover off. There should be three screws on the inside that will take the mirror from the door. (at least thats how mine are mounted.)
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You have to take the inside panel off to access the other bolts.
    [​IMG]FUN WITH 31's![​IMG]
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    What Wheels said is correct, just remember it is a bit tricky, once you remove the screw from the bottom of the triangle section, to slide the cover up. Be careful you don't mess your paint up.
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;http://www.blazzinor.coloradok5.com
  5. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    To make it a little easier, you can pull to cover (screw's on the bottom) Move it up the shaft, then just loosen the others bolts. This will let you slide the whole mirror assembly off. Then you got easy access to get the stuff the rest of the way off. Takes about 3 minutes a side on mine. Pulled mine off to dechrome em. Didn't take long at all
    Kyle
    89K5
  6. delta9blazer
    1,646
    cool, thanks. i'll try to remove the passenger side at break.
  7. Topher
    Topher Registered Member
    May 12, 2000
    81
    North Texas (DFW)
    Kyle, could you please describe how you dechromed your mirrors? I've been wanting to do this to mine as well; actually I was either gonna paint them flat black or buy black aftermarket ones since I want to eventually get rid of all the chrome on my rig (mirrors, bumpers, trim, etc.). But your idea intrigues me.
    Chris
